HELP! C230K Sedan Big Brakes w/ Rims
If it is the correct hub bore, then you'll need to buy at least a 8mm spacer or a 10mm, i would lean on the 10mm spacer just make sure it does clear. But remember if you do get spacers you'll need new lug bolts as well, so if you get 10mm spacers you'll need 50mm lug bolts because our stock shaft length is 39.9mm so you have to add 10mm to it.
if you really dont care about the center caps then you can take the wheels to a machine shop and have it bored all the way through to 66.6
