For Sale: H&R Front Sway Bar!
Subscribe
Aug 19, 2012 | 11:32 AM
I purchased a slightly used H&R front sway bar from a member on here that stated it would fit a 4matic. In short, it doesn't. I'm selling this part for that reason alone. It is a beast of a bar. I'm asking $250 obo. It doesn't do me any good since it doesn't fit. Below you could see the stock 4matic bar next to the H&R and the difference in shape.
For Sale: H&R Front Sway Bar!-h-r-sway.jpg
Reply 0
Aug 19, 2012 | 12:54 PM
Same one that goes on the C350?
Reply 0
Aug 19, 2012 | 04:31 PM
Yes as long as it is rear wheel drive. I'd have to convert my car to RWD, which I'd rather not do. Awesome part, my entire car is H&R except the front sway, which is upsetting. Damn 4matic
Reply 0
Aug 20, 2012 | 10:29 AM
It will fit the following models: (Non-4matic)
w203: c230, c320, c350 c32, c55
w209: clk320, clk350, clk500, clk550, clk55
Reply 0
Aug 20, 2012 | 06:54 PM
There is a difference between 10mm endlink and 12mm endlink. Of course you can drill it out from 10 to 12, but you cant put 12 on 10 unless you drill the endlink hole on the strut.
So NO it does not fit all 203 without making the endlink holes proper size.
Reply 0
Aug 21, 2012 | 09:15 AM
If anyone has any questions you can contact H&R directly with your make & model, however the information above was pulled from their website.
Reply 0
Aug 21, 2012 | 05:50 PM
H&R sells two type of front sway bar. One for 10mm endlink and one for 12mm endlink. Part numbers are different.
Reply 0
Aug 22, 2012 | 09:19 AM
The part FS has a 12mm end link hole.
Reply 0
Explore
Aug 22, 2012 | 11:35 AM
Ive got this exact sway bar on my car. Its awesome. Get it + AMG end links + mod the struts to fit the AMG links. Completely worth it. Every penny. Its magical! GLWS!
Reply 0
Aug 23, 2012 | 08:59 AM
I put a C32 f & r sway bar on my stock C230 (non sport) and the difference is night and day, best $50 mod (not including the end links) I have ever done. I had to drill out the tab on the strut which I did in two parts, stepping the drill sizes rather than drill a bigger hole right away (7/16 15/32) good luck finding a 12mm bit. There was no problem drilling the hole (soft steel)
Reply 0
Aug 23, 2012 | 09:09 AM
Thanks for the info guys. Really wish I could have had this installed. The H&R bar is so much nicer than stock and I could only imagine how it would drive. Arg!
Reply 0
Aug 23, 2012 | 06:49 PM
Attached are some pictures!
For Sale: H&R Front Sway Bar!-imag0295.jpg   For Sale: H&R Front Sway Bar!-imag0296.jpg   For Sale: H&R Front Sway Bar!-imag0297.jpg   For Sale: H&R Front Sway Bar!-imag0298.jpg
Reply 0
Aug 26, 2012 | 05:39 PM
Quote: There is a difference between 10mm endlink and 12mm endlink. Of course you can drill it out from 10 to 12, but you cant put 12 on 10 unless you drill the endlink hole on the strut.
The Bilstein struts come with a little adapter you put in the 12mm hole to make it 10mm. Not sure how readily available this little widget is, but they are out there.
Reply 0
Aug 26, 2012 | 07:03 PM
Quote: The Bilstein struts come with a little adapter you put in the 12mm hole to make it 10mm. Not sure how readily available this little widget is, but they are out there.
it's a sleeve washer thing. that's if people are willing to look for them. easier to just take a drill and go to work and change out the endlink.
Reply 0
Aug 27, 2012 | 11:45 AM
Quote: it's a sleeve washer thing. that's if people are willing to look for them. easier to just take a drill and go to work and change out the endlink.
Agreed. Drilling your strut is like an extra minute per side on your install.... Super easy - its what i did!
Reply 0
Aug 29, 2012 | 12:06 PM
Great information! I did not know this! Great option if someone doesn't want to drill the strut.
Reply 0
Sep 4, 2012 | 08:52 AM
Reply 0
Sep 4, 2012 | 09:02 AM
pmed
Reply 0
Sep 7, 2012 | 02:15 PM
Reply 0
Sep 13, 2012 | 04:51 PM
***Price Reduction***
Now asking $200!
Paypal ONLY!
Reply 0
Sep 13, 2012 | 07:04 PM
hold it till tomorrow and i'll take it
Reply 0
Sep 13, 2012 | 07:43 PM
Pm'd
Reply 0
Sep 18, 2012 | 12:41 PM
Part is back on the market as previous sale fell through.
Reply 0
Sep 28, 2012 | 06:05 PM
SOLD!
Reply 0
Subscribe
Currently Active Users (1)
