washer nozzle adjustment
Old Oct 22, 2012 | 07:50 PM
jtalbert's Avatar
2004 C240 4Matic
I have had my C240 for a year and to me it seems like the fluid hits the windshield at the oddest spots. Ayone have a diagram that shows where the fluid should be hitting the windshield? The drive one, one nozzle hits both the center of the window and almost shoots over the windshield.
Thanks.
Old Oct 22, 2012 | 09:37 PM
Glyn M Ruck's Avatar
Super Moderator
This should give you some idea. Unfortunately W203 is not covered.
https://mbworld.org/forums/attachmen...er_diagram.pdf
Old Oct 22, 2012 | 11:28 PM
Akhafeez's Avatar
2004 C240 4matic, 2009 C300 4Matic
some told me to adjust it with tooth pick.. haven't tried it... so i'm not sure if it works or it might mess it up
Old Oct 23, 2012 | 03:15 AM
Moviela's Avatar
To properly adjust the nozzle you need one of these little beauties:
Amazon Amazon
One end is pointy to assist in moving the nozzle, and the other end is squared off to clean the crusty slime out of the jetway. The caps are o ring sealed to keep the tool nice between uses.
Old Oct 24, 2012 | 08:05 AM
jtalbert's Avatar
2004 C240 4Matic
Glyn,
Thank you very much, this helps a lot. One of my jets on the driver side is way out of whack and I will be adjusting it this weekend.
Thanks again.
Old Oct 24, 2012 | 01:16 PM
Gilgorm's Avatar
12 BMW 535Xi; Retired 02 C230 Sport Coupe
Don't use a toothpick. IMO, the possibility of breaking off the end is high.
Use a thick straight pin or large needle. As I recall the noozles are slightly adjustable to re-direct to where you need the fluid.
Old Oct 24, 2012 | 01:31 PM
samaritrey's Avatar
Super Moderator
THE C350
I used a needle when I first got my car
I also still have it in my glove box if you would like to borrow it
Old Oct 24, 2012 | 04:05 PM
jtalbert's Avatar
2004 C240 4Matic
Thanks may do that, still want to, if you still have time have you do star on my car again to see if any code have come up. I do have a check engine light on right now that goes on and off for a bad O2 sensor that I need to get replaced soon.
Old Oct 24, 2012 | 07:50 PM
samaritrey's Avatar
Super Moderator
THE C350
Yeah you still have my # right just let me know I should be around the rest of the week unless I make another trip to see GF which is usually a last minute I want to see her I am going right now type of trip.
Old Oct 25, 2012 | 07:19 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
That's what I use. My suggestion would be that if someone can't adjust their nozzles without breaking off the end of a toothpick, they should probably make an appt at the dealer and pay $150 to have them adjust the nozzles.
Old Oct 25, 2012 | 11:06 AM
Gilgorm's Avatar
I was referring to the pressure required to move the nozzle. My car was very difficult to move and would have broken even a super toothpick made of hardwood.
