Sunroof not closing all the way
Initially the sunroof wasn't working, only the shades were working. So I went ahead and looked for a solution to my problem and found http://www.benzworld.org/forums/w203...oblem-fix.html.
Tried that solution and the sunroof started to open up an inch at a time. However, I could not close sunroof completely and started hearing the grinding noise. Did a reset and played around with it for a few hours and then ended up not being able to close it all the way.
It doesn't close now unless I help it by pushing the roof from the outside while pressing the switch. It stops right at the end and does not want to tilt down. I do not understand the grinding noise either. It opens fully but a few inches at a time.
Video of the problem
https://dl.dropbox.com/u/50143419/20...2023.03.41.jpg
https://dl.dropbox.com/u/50143419/20...2023.03.49.jpg
https://dl.dropbox.com/u/50143419/20...2023.03.57.jpg
https://dl.dropbox.com/u/50143419/20...2023.04.05.jpg
https://dl.dropbox.com/u/50143419/20...2023.04.08.jpg
I got the Mobil 1 synthetic grease and cleaned up the track and greased it up. However, the problem didn't go away. I had a feeling that the motor might have a problem. So I started to manually close the sunroof. It took a few minute but it finally closed all the way.
At this point I am almost certain that the motor is gone and cannot supply enough power to move the sunroof. I unplugged the sunroof and the shade motor for now. I am going to read on how to remove the headliner to get to the motor.
My plan is to swap the motors as I remember reading that the shade motor does not need much power anyway and can replace the sunroof motor if needed. If swapping the motors doesn't help, I am going to inspect to see if a mechanical part is bent or broken. Planning to do this during a weekend where I will not need the car.
Please let me know if you have any suggestions or helpful links that I could use.
Search for pano sunroof fix or something like that,.... Todd (C230 Sport Coup) did an extensive writeup on maintenance and fixes for it.
From your video, that grinding sound is likely the gear are chewed up,... Or it could be that the plates that sandwich the motor is bent outward,... another thread by Mike (mbryant107) on how to fix that,... another possible fix for the bent motor is to take out the plate and put in a new plate.
