Need help removing instrument cluster...
Old Aug 1, 2003 | 01:02 PM
SilverStar's Avatar
02' Silver C230 Sport Coupe
Hello everyone, does anyone know how to remove the instrument cluster. I know you're supposed to hook a hanger on the two holes on each side of the cluster, but something will not release my cluster.
Any suggestions would be appretiated!
Old Aug 1, 2003 | 03:11 PM
moomeh
Guest
Posts: n/a
STFF.
here is a start:
https://mbworld.org/forums/showthrea...rument+cluster
Old Aug 1, 2003 | 03:30 PM
SilverStar's Avatar
Never mind....I got it!!!
Here's what I took it out for...
Attached Thumbnails Need help removing instrument cluster...-122-2271_img.jpg
Old Jun 21, 2006 | 07:19 AM
Quad Pipe's Avatar
C55
Cleaning inside cover of instrument cluster
I seem to have what looks like condensation marks on the inside of the clear cover of the instrument cluster of my C32.
Has anyone ever removed their instrument cluster? Easy, difficult?
Old Jun 21, 2006 | 10:15 AM
Quad Pipe's Avatar
C55
Okay, after some searching, found out how to remove the cluster but a question regarding the cluster to which I have not found an answer.
Can you get to the inside of the lens to clean it without too much difficulty?
Old Jun 21, 2006 | 05:37 PM
mbz4810's Avatar
08 CLS550 Diamond White 09upgrades
I think you can do it.!!!
Dont forget to post detail write up and pics.
Old Jun 21, 2006 | 07:01 PM
20FHK02's Avatar
2002 C230 Coupe
After you take out the cluster unit. Just pop some clips/screws behind it then you can separate the clear cover and the circuit board.
Old Jun 22, 2006 | 09:45 AM
Quad Pipe's Avatar
C55
I just don't know how comfortable I am with fashioning a tool for the removal of the cluster out of coat hangers...
Old Jun 22, 2006 | 11:34 AM
20FHK02's Avatar
2002 C230 Coupe
Or you can cut 2 pieces of metal wire thick enough to fit the holes. I used to use 2 small screwdrives for the job.
Old Jun 22, 2006 | 11:44 AM
MBM41NYC's Avatar
2025 CLE 53 AMG
CAREFUL!
Careful w/ what kind of rag you use to clean the plastic. I did this once on my old Camry, and the plastic was hair-lined scratch to hell after I was done. When direct sunlight hit the cluster, it'd light up like a rainbow.
I used an all cotton cloth, but to no avail did it work. Try microfiber.
Good luck.
Old Jun 23, 2006 | 09:53 AM
Quad Pipe's Avatar
C55
Ah, thanks for the advice. I'm now even less keen to talke on this exercise
Old Oct 14, 2008 | 01:26 AM
pawe's Avatar
'05 C230
removing the cover for the instrument cluster
as the title says, how do you remove the plastic covering the instrument cluster? there's moisture inside and i want to clean it up. thanks!
Old Oct 14, 2008 | 01:41 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
This topic has been covered extensively. Please properly search the forums.
I will merge your posting along with other similar threads to help you along.
And also, search through this thread for some clues:
https://mbworld.org/forums/showthread.php?p=2468566
Carlos
Saprissa@aol.com
Old Oct 14, 2008 | 06:19 AM
Glyn M Ruck's Avatar
Super Moderator
Just wash it thouroughly in clean water with Dawn in it & dry with a chamois - no scratches. If you don't want to touch it at all get some photographic wetting agent and do the final rinse in that & allow to dry out of the sun. Will be spotless & unscratched
Also - beware of microfibre cloths - They scratch some plastics
