strange behavior 2002 c-class w203
here is my problem:
i have a 2002 c230 coupe, on jan 10, was out running errands, car running fine, went from one store to another in the same parking lot, and when i turned off the car, the abs round light came on, (dont know if it has anything to do with the problem). i got a weird feeling, so i thought i would just call it a day and go home. i went to start it up again, and nothing...no engine turnover at all. the lights were on, all the instrument panels, but no start. called a friend to jump start, and the battery wd not jump. called a wrecker, could not put it into neutral, he mentioned something about the neutral safety switch, (security or something..) so they dragged it onto a flatbed and towed it to my mechanic. in the morning i brought the keys over to him, and waited for the call. 4 days later, i called him, and he told me that the car started right up, no problem, he ran a series of tests (dont know which ones)and could not find anything wrong with the car. it started up everytime. so i went to pick it up. it started right up, (he didnt charge me btw ). drove to my home, just right up the street, got in my drive, turned it off, went to turn it on again, and nothing...
called him back, the owner wasnt there, spoke with the front desk who said to bring it by in the morning if it started. well it didnt, and i didnt call back. a few days later the owner called me and said he would like to come to my house, see if it would start and bring it to the shop to check it out. (i live within walking distance) so he did, he was able to jump start it,(but for some reason i was not able to). brought it to the shop and started troubleshooting. he said he put a new batt in, and it was starting, but noticed that something was pulling from the battery. he kept it for another week, and finally was not able to find anything else wrong. thought it may be starter, but wasnt sure, didnt want to charge me to put one in, to find out later it was not the starter. he said he put in about a thousand man hours into it, but couldnt find anything. (again, no charge. good man, just wasnt able to find the prob) he put it back together and it started up, and we drove it to the dealer, thinking it was the key. they checked it out, said to get another key, and so thats what i did. i just got it home, backed into the driveway, just in case, and guess what....wait for it....tried to start and NOTHING...
so, i was wondering if anyone has had this problem, and what it might be. the fuel pump shakes when the key first turns, then turns off. i have a video of it, not sure where i can post it. im just at my wits end, anything would help.
so its not:
the key
the battery, it has a charge
diagnostics showed no code
i thought it may be electrical, but im no mechanic...
it seems to start for everyone but me, the only thing that is the same, is that i drove it a few miles to my home, pulled in the drive, and then it wouldnt start.
thanks in advance, for any help
bbmcgee
https://mbworld.org/forums/mercedes-...ery-drain.html
i was cleaning the interior of my car a few months ago, and took out the passenger seat, to vacuum, and decided to leave it out, for storage room, because my hatchback wont open without the blade key. (i am a flt attendant and of course need to stow my luggage every time i go to work, so it gets old having to look upside down to find the blade key entrance). when i read about the srs light draining the battery, i thought maybe that may be my source of drainage because the light is on all the time, due to the passenger seat not being there. i just put the seat back in, and plugged in the yellow srs wires. (i already had the seat motor/module issue draining the battery, its been unplugged for years,so i live without that convenience as well). i also tried to jump start it again, my battery is a 12 volt interstate, 850 cca 1000ca and we tried jumping with a 12 volt 700cca 875 ca battery, and it would not start...just wanted to add some details thanks
You have to be really careful jump starting a Mercedes. Mercedes doesn't recommend jump starts. Read owner's manual and follow steps carefully.
You might have fried the frontSAM???
Hook up an OBD2 scantool and read code if any,.... MB Star would be best,...
Start checking fuse, relays,... and especially look for loose connections, bad grounds,...
really sounds like a loose connection issue.
List all the steps you take when you start the car,... key in- observations,...key to position 1 - obsevations, key to position 2 - observation,... key fire ignition - observation,...
When exactly does the fan under the hood goes off,... and does it spin in high mode like a turbine engine? Very loudly? If so, for how long,....
Post your video on YouTube and provide a link here.
Write proper english with full words,... none of this "n wd" short form crap,... I'm not going to waste my time trying to figure out what you're trying to say.
Auxiliary coolant pump for interior heating is the fist size cylinder attached to coolant reservoir.
im going to get a ride over there to see if it starts, and if so, maybe it starts having problems when it gets heated up...ill keep you all posted
Good luck!
ps. Check fuse 52 & replace with 20 amp.
When the gear lever did not move with the engine running that sounds like the brake light switch is bad. The switch actually signals the SAM that a foot is on the pedal, and the SAM then commands the shift lever to be unlocked as well as switch on the rear brake lamps.
None of these items would throw a code.
If the neutral safety switch were OK, I might suspect worn brushes in the starter. When cold they can slide easly in their channel, but when hot they may expand enough to stick, and being worn down the springs might not have enough "push" to move them in contact with the armature.
Electrical problems can be such a headache. Do you know how copper wire was invented? Two pilots found a penny at the same time. (this thread needed a little humor)
A bad brake pedal switch would prevent moving the shift lever, but it would not prevent starting the car, assuming the car is in neutral or park. You can actually stand outside and start the car by reaching in the window.
) so you think its the neutral safety switch and the break light switch? that would make sense about the heat thing, cause thats it wont start, it starts at the shop because its cold...also i dont understand why the interior lights would suddenly not work also im trying to post a pic of the ---- thing on my dash... ps i noticed that the superbowl was played at the Mercedes Benz super dome, and they had electrical problems too...lol
I wonder about your body earthing strap connections or bad terminal connections on your battery.
I have heard on this site that poor batteries can cause these sort of problems.
You need a systematic approach to this . Check everything step by step.
Good luck.
Good luck.
Also ~ without a Star we are making educated guesses as to problems. These cars were designed to depend on Star diagnostics.
Trouble is DIY becomes less appliciable. !! but so far I am lucky that I have not had to call on the services of the dealer ...touch wood .
It happened to me before , when I give the car to the dealer it works , He says, nothing wrong with it . when i take it back , it works one time, then not. One day after i got the car from the dealer ,I went to pick my daughter from school , when i came back to the car , the car didnot start !!!. I went under the car infront of the school and found out the connection to the starter loose , some time it touches , sometimes it doesnot , all what i did is tighten the nut to make a tight connection. I Never had the problem again . I was so happy, I didnot even check back with the dealer .
Good luck . Let us know .
