Eurocharged ECU Tunes - $299 (220, 230, 230k, 240, 280, 320, 420, 430)
Old Mar 18, 2013 | 09:54 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Talking Eurocharged ECU Tunes - $299 (220, 230, 230k, 240, 280, 320, 420, 430)
The following ECU tunes (through MY2005) are on sale for $299!
In addition to the increased power gained by optimizing the fueling and timing maps, the tune also raises the speed limiter (200+ mph), raises torque limiters and improves throttle response!
This price includes the remote tuning cable and our new Euro-Flash software, allowing us to email you files to tune your car from the comfort of your home. No need to remove the ECU; the whole process only takes only minutes!
The basic software also includes the ability to read and clear CELS! (check engine lights)
Place your order HERE.
Please include in the comments section of your order the Year/Model of your vehicle
Old Mar 18, 2013 | 11:08 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Anyone tried this? Does it work?
"230K" 18 HP.
Which 230K engine are we speaking of?
What about a pullied engine?
Got Dyno?
Old Mar 18, 2013 | 11:26 PM
loungn14's Avatar
SPONSOR
"230K" 18 HP.
Got Dyno?
we have been tuning on the forums here for years...all tunes are customized for your mods, elevation, gas etc.
https://mbworld.org/forums/c-class-w...420-430-a.html
https://mbworld.org/forums/c-class-w...une-c230k.html
https://mbworld.org/forums/c-class-w...endations.html
http://www.eurocharged.com/customer-testimonials
Old Mar 19, 2013 | 12:03 AM
If you can't answer the question which C230K engine are we speaking of, or is you have a tune for pullied engine, why would i buy from you?
Good to hear you have been on the forums a long time.
So have I. Longer in fact.
But that did not answer even one of my questions.
Old Mar 19, 2013 | 12:06 AM
Ha, you linked me to a thread where you don't say anything and the last person giving advice was me. Some kind of joke?
Old Mar 19, 2013 | 01:19 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
yo go on the eurocharged website they differentiate between the 2.3 and 1.8
i guess the op is really lazy and uninterested lol!
wooot finally the discount comes...i wonder how many people are buying tunes
and it works. everyone says eurocharged is the best
Old Mar 19, 2013 | 12:14 PM
phister's Avatar
06 C230 SS 6spd
eurocharged is good but I think OETuning is a bit better. I have eurocharged tune with no compliants except for them saying i could remote tune and when we tried they said my ecu wouldnt allow and need to ship it in.
cale an old member here had a tune done by eurocharged then had it tuned again with OE and he says OE was way better. I might call up OE and see if they can muster out a lil more hp on the car.
Old Mar 19, 2013 | 03:41 PM
loungn14's Avatar
SPONSOR
The original link I posted references the website product section which shows the various engines as requested. I also indicated that we build each tune custom to the mods so a pulley wouldn't be a problem.
Just so its in the thread as requested the tuning covers the 1.8/2.3/2.5 engines.
Link
we had quite a few orders last night and this morning! The new software really makes the difference as you can simply email files back and fourth and flash the car when you want to.
with such small margin on these engines it will be very hard to make up a "noticeable" difference. Typically we have found it takes approx 10-15whp to "feel" a difference in the tuning.
Old Mar 20, 2013 | 08:56 AM
Laloggia's Avatar
2002 C230 Coupe
Had this done remotely a few weeks ago on my stock 2.3k. You will definitely feel the difference...reminds me of the Honda v-tech pull. Throttle response is snappier and the car will pull faster from 3000 - 6000 rpm's. I think it's well worth $299 to wake the car up.
Old Mar 20, 2013 | 09:35 AM
loungn14's Avatar
SPONSOR
Old Mar 20, 2013 | 11:11 AM
rocafel1a's Avatar
05.C230K.SS
Possible interest. I have a 2005 C230k ss. Any testimonials?
Old Mar 21, 2013 | 04:51 AM
c230K415's Avatar
AMG GTS
Just a couple questions!
1) After reading the relevant threads - how about bringing back that good ol $250 price tag
2) For the 1.8L M271 motor, are you able to flash remotely (use supplied cord, transmit files, flash)?
3) I understand each tune is custom tailored...for a tune focused on power gains (+18hp/+20tq for the C230K I'm seeing)...what is the potential gain/loss in gas mileage?
Old Mar 22, 2013 | 12:44 AM
SemperFudge's Avatar
2006 C230
im definitely interested but i need to hear from guys with the m272. testimonials, anyone?
Old Mar 24, 2013 | 10:38 AM
Darren_0203's Avatar
03 CLK55 AMG, 02 C240
What kind of modifications in your experience work for the best results in a c240? Should I first get injectors, fuel pump, delete the cats, etc?
Old Mar 24, 2013 | 11:00 AM
phister's Avatar
06 C230 SS 6spd
you'll only really need update the fuel injectors and pump if you're running high hp. the injectors and fuel pump can handle quite a bit of power before needing to be replaced. If I remember correctly our injectors really only use up to 65% of the injectors cycle duty at wot. Bosch injectors, I believe thats what our cars use can max out at 85% for safety. Of course this max out is only at redline. this means that our injectors can have about 20% of possible gain on the injectors plus a little more. but you also have to take into account the fuel pressure. most shops recommend tuning the cars at 80% cycle so theres room to increase power later. so getting larger injectors is going actually cause you to lose power. Only if plan on boosting the hp by 100hp or so should you need to increase the injectors and fuel pump.
Old Mar 24, 2013 | 11:12 AM
100hp increase would be sweet, but that's unlikely unless I dump a bunch of $$$$ or build a turbo kit, both of which I'm trying not to do.
For the 240 I think it said 17-20 hp increase on stock, so I'm wondering if there's anything I can get before a tune to get more hp without dropping insane amounts of cash on my daily driver.
Posted from Mbworld.org App for Android
Old Mar 24, 2013 | 12:30 PM
phister's Avatar
06 C230 SS 6spd
The tune is going to be the best bang for buck. Headers and engine work is going be money.
Old Mar 24, 2013 | 12:41 PM
The tune definitely is the best bang for the buck, just wondering what other modifications would compliment it the best. I can make my own headers and eliminate the cats at work if it would really make a difference, I say that because it doesn't always. I've done a catback already.
Old Mar 24, 2013 | 12:46 PM
I'm not doing internal engine work, it's just not worth it on a car this old. I'm just looking to make it a little more fun to drive. I've already got plans to pay this off ASAP and get a clk55 amg, or something of that nature.
Old Mar 24, 2013 | 01:21 PM
Ribo89's Avatar
a Tank
HAPPY/SATISFIED customer since 2011! This is the BEST BANG FOR YOUR BUCK @this price! Miss seeing the E55 beauty in Naperville
"My original post in 2011
I got the ECU Tune on my C320 today!!!!!!
Drove the car for 20miles and I could DEFINITELY feel the INCREASE in HP&TRQ. The car feels much more ALIVE(before it was pretty sluggish) and faster off the line and it pulls REALLY nicely over the stock. I noticed an increase in throttle response too. Also, the engine sounds MEANER! Over all VERY HAPPY! HIGHLY RECOMMEND THIS TO ANYONE LOOKING TO IMPROVE THEIR CAR!!
Next step c32 air box and K&N filters!!
Thanks EUROCHARGED for the AWESOME DEAL and SUPERB PRODUCT/WORK!
-riBO"
Old Mar 24, 2013 | 11:49 PM
wheelz's Avatar
AMG's
PM sent.
Old Mar 25, 2013 | 03:19 AM
TTR's Avatar
TTR
R129 SL500 & W140 S500
Applicable for us Canadians or do I go through the Canadian site?
Old Mar 31, 2013 | 11:20 AM
wheelz's Avatar
AMG's
Sent an email with a question. Standing by to purchase.
Old Aug 22, 2013 | 05:43 PM
marquisalley's Avatar
2004 C240 4Matic
I just saw on the site there are dealers in Jersey. Just wanted to know, will they do the ECU there as well or they are just dealers?
Old Sep 10, 2013 | 02:55 PM
loungn14's Avatar
SPONSOR
yes they can do it there, but the good thing about the software here is you can flash the car yourself from the comfort of your home..
