Front driver side door won't lock or unlock after reinstalling door panel
Like the title says, the door won't lock or unlock after reinstalling my door panel, was working fine before. I took the door panel off because every time I would close the door, it would sound like there was something loose inside. Turned out to be a broken rivet on the window regulator causing it to shake against the the door every time it closed. Anyway, I put everything back together, close the door and lock the car and notice all the doors lock except the one I was working on. It won't even let me lock it by hand because the door pin wont go down. Also tried locking by putting the key in manually and it still wont move. I took everything apart again to see what could be the problem and noticed when I put the latch down by hand, the latch that grabs hold to lock onto the car, that I could move the door pin freely but when the latch is up, I can't because the latch is blocking the plastic piece that's connected to the door pin from moving up or down. Here are some pics to help explain what I'm seeing.
Latch up.
![](http://imageshack.us/a/img5/3331/imag0517x.jpg)
![](http://imageshack.us/a/img838/4590/imag0519.png)
Latch down in lock position
![](http://imageshack.us/a/img94/1598/imag0515b.jpg)
![](http://imageshack.us/a/img19/4052/imag0520.png)
Does anyone know if something popped out of place that could be causing this? Or could someone take pics of how this looks on their car so I can see if anything looks different? I looked on the passenger side to see if there is any difference, and on that side, you can't even see the plastic that moves up or down with the door pin. Not sure if the driver side should be different since it has the key hole. Anyway, any help or advise would be really appreciated.
Latch up.
Yeah, unfortunately the door still doesn't lock nor does the door pin want to move up or down. Only when I pull the latch down by hand I'm able to push the door pin up and down by hand. Even then, when I try to use the remote key to test the lock and unlock, the door pin would only work in the unlock mode and would not lock or move when I try to lock with the remote key. This is all with the door open and latch down. I have to put the latch back up in order to close the door shut and when I do that the pin goes back to not moving at all.
Super Moderator
Just to be sure you did screw in that last plastic cover and do try to lock it with the door closed? For some reason I remember having an issue like yours and can't remember which fixed it.
Yea, I did. Everything was put back together and I closed the door and locked with key remote and the door pin wouldn't move. You can hear and see the door pin shake a little as if it's trying to lock but it wont. Same thing happens when I try to lock from inside the car. Pin just doesn't want to move.
Yea, 3 times already. Took the passenger side off too just to compare both. Did everything the same and that side works fine. Not sure what went wrong with the driver side. ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Debating of just taking the whole door lock actuator out to see what gives.
have you tried working the lock knob while you hold the outside door handle in the up/open position?
Probably a long shot, but on our Honda Accord you cannot push the lock knob down while the door is open unless you pull up the outside door handle. The last time I worked on the drivers door on the Honda, the lock knob also got jammed and wouldn't move anymore. Fidgeting with it and eventually trying to lock it with the door open by pulling up on the outside handle, seemed to unjam whatever was jammed.
I know -- not a very scientific resolution, but worth a try in case you have a similar issue.
Pretty sure I've tried that but next time I'm by the car I'll do it.
I took the plastic piece off that attaches to the side on the inner door to mess with the latch again today. I didn't do anything that I haven't done already but when I put the plastic piece back this time and tried to lock with the remote key, the door pin would move rapidly up and down on it's own this time but stay unlock. So I keep pressing the lock and unlock button thinking maybe it would reset itself somehow but it doesn't, it just keeps moving rapidly then stops in unlock while the other doors are locked. I then press lock again when the other doors are already locked and it moves rapidly up and down again BUT this time it locked.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I have to double lock for it to lock if that makes sense. So I press lock, the driver door pin moves rapidly up and down for a second and stays unlocked while the other doors lock. Press lock again, driver door moves rapidly but locks. Not sure if that is a step forward to fixing this or if the door lock actuator just went bad. Any thoughts?
Well, I finally got the lock to work. I was messing with the pin today, putting presser on it with my hand while it would go up and down rapidly and noticed when I did that, it would lock it one shot but only with slight pressure on the pin. I kept doing it for a few times then locking and unlocking with the remote with out my hand, letting it still move up and down rapidly and then I just locked and unlocked on it's own after pressing the button a few times. Not sure if it reset or what, but it worked. Hopefully it stays like that. Thanks for everyone who chimed in.
Yeahh...scratch that. The pin started going rapidly up and down again when I tried to lock, just not as often now. I think I might just replace the damn thing as it's becoming very annoying and I can't seem to find a fix.
Hmm, so could the pogo issue be caused by taking the door panel off or is it just a coincidence?
Man, now I'm scared to replace the broken interior door handle O_o
Maybe related --
Whenever I remove the driver's door panel, the driver's door won't lock by itself until I replace the panel and start the car. While I'm working on the car, if I needed to lock it up for the night I would have to lock that door from the inside with the door already closed.
None of the other doors do this -- only the driver's door. I assume this is a safety mechanism that was intentionally designed into the car.
I have removed the door panels quite a few times now and have noticed this at least a few times.
