Cranking but not starting any input will be appreciated.
After reading a lot of threads I started working on the Merc.
Last week I cleaned the MAF with MAF cleaner and the car was driving fine, and suddenly on an incline the car cranks but does not start.
I thought it could be the CPS, unplugged the unit behind the Firewall/Air box and it looks fine no oil residue.
Took of the tapit cover checking the timing chain and it looks fine, got new plugs in the beast, and still no starting.
Any other advise, someone can share with me, I can hear the fuel pump and it looks like there is pressure on the fuel line.
c230 Coupe 2005 M271
Warm Regards
Stephan
The sprockets is the most expensive part on the
Got new valves, guides, tensioners and new CPS.
Car is driving like a beast now.
Thanks for all the help guys
VVF: At the moment it has 200000 kilometres on it.
mis3: The total cost was R17000 converted to dollars will be 1713.80 US Dollar, but the big problem is the cam shaft sprockets, that is the most pricey, from the dealer it is 806.33 US Dollar EACH, there was an engineering shop whom refurbished the sprockets for much less than the initial 806 dollars. Got it for 604.87 dollars for both, but gave the old ones back.
Glyn: Funny Enough Glynn, I did not even remotely hear any noise, but that may be because the music is always so loud
Thx for all the help guys
Really appreciate all the input on this site.
I wont make the same mistake again, to costly.
