Been away.. status on Panic AND Netherland arming beeps?
Please enlighten me.
I read the service reicept and it said that they had replaced the alarm module (which is somehow near the right front wheel well) and a harness (which got corroded because water got to it...i dont understand how)
I talked to the service manager about it earlier and they are not sure why it does that now and they asked if they wanted it removed but I declined.
I can take videos and stuff to prove it if you guys beg enough.
1. When I click lock once on the remote...the signals blink 3 times and the alarm chirp sounds 3 times
2. When I click lock again...the signals only blink 3 times (no chirp)
3. This does the same with the unlock sequence, chirping only on the first click and not the second click to unlock all the doors
4. Alarm can still be sounded at any moment, in lock or unlock mode.
I looked in the rear fuse compartment to see any changes but I cannot confirm this because I dont have a fuse layout or any previous configuration record. (I saw on the report that they replaced a fuse)
So far this confirms one thing...something had to be changed through the diagnosic computer. It does not seem exactly like the Netherlands feature because panic still works.
Not at all like a traditional car alarm chirp.
Now that I think about it a video would be great. Not that we don't believe but at this point to rule this out one way or another. I agree with the above post... MUST HAVE INFO!
P
I made a video with unlock, lock, and panic sequence but I have one problem...you can't really hear the beeping noise when you lock or unlock the car in the video. I'll try again to see if it works better without the lawn mower from the neighbor in the background.
I'm using a digital camera to take this video
