Old 06-16-2015, 01:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Maf and throttle body clean w203 m112
Old 07-18-2013, 09:47 PM
Ivanrad's Avatar
2001 C320 Automatic
How do I remove and clean maf I have crc maf and throttle body cleaner my w203 has 134k miles. I'm sure it needs to be cleaned . Do you have to replace gaskets ? Any tips / instructions will help
Old 07-18-2013, 10:59 PM
SPONSOR
PelicanParts.com's Avatar
Answer
http://www.pelicanparts.com/techarti...eplacement.htm
whunter@pelicanparts.com
Old 07-21-2013, 06:37 PM
Ivanrad's Avatar
2001 C320 Automatic
found it
Old 07-21-2013, 06:58 PM
Ivanrad's Avatar
2001 C320 Automatic
found a thread i guess you have to just unscrew 4 screws.. and becareful with the pcv hoses.
Old 07-22-2013, 03:07 PM
Ivanrad's Avatar
2001 C320 Automatic
bump
Old 07-22-2013, 04:05 PM
Super Moderator
Glyn M Ruck's Avatar
https://mbworld.org/forums/c-class-w...+throttle+body
Old 07-22-2013, 06:28 PM
Ivanrad's Avatar
2001 C320 Automatic
cleaned my maf and airfilter re oiled it with minimal oil K&n, cleaned the throttle body. NIGHT AND DAY difference car is smooth off the line no more hard shifting. I even reset the throttle calibration my holding the pedal to the floor and resetting it. Amazing results here if anyone wants pictures i will post later on. This is by far the best mod
Old 07-23-2013, 05:05 AM
Super Moderator
Pleased it's sorted & you are happy!
Old 07-29-2013, 03:41 PM
Ivanrad's Avatar
2001 C320 Automatic
okay so today i got this
https://i.imgur.com/ZMkptA1.png
I checked all connections everything is connected. i wonder why after driving it 150 miles its already giving a code. it happened when i was stopped at a stoplight.. weird
i guess im going to have to run some more tests i did a throttle reset using the pedal.
My next step is running the diagnostics on the maf from my obd2 app on my android.
Impressive results gives me the error code everytime, pairs up in 2 seconds. and its got tons of diagnostics and details. will keep you updated.
maybe the maf just went out coincedentally
Old 07-29-2013, 07:41 PM
chazman's Avatar
2006 C230 & 2002 C230
Even though the code came up while stopped, that's not when or only the time the actual failure occurred. According to my prof grade scanner, the ECU accumulates the number of the total failures and when it reaches the certain number (eg. 10 times or 50 times), the CEL (Check Engine Light) illuminates.
So, there are (at least) two types of codes stored in the ECU.
Pending - you don't see the CEL on the dash yet but ECU has been registering. This will be erased by itself if the engine operates w/o any further substandard signal from sensor(s).
Stored - you see the CEL on the dash. This will not be erased by itself in the ECU (CEL might be turned off by itself though). Stored codes can only be erased manually.
Old 07-29-2013, 08:53 PM
Ivanrad's Avatar
2001 C320 Automatic
ahh okay. should i unplug the maf connector and determine if its still the sensor? why would this happen after cleaning i seriously babied the sensor when i had it out. i reconnected everything and double checked , to see if everthing was in order. every hose connector and plug is right. now why the rough idle..
Old 07-30-2013, 11:43 AM
Ivanrad's Avatar
2001 C320 Automatic
If anyone knows why after a careful and gentle maf cleaning why this would happen?
Old 07-30-2013, 12:34 PM
Super Moderator
IAT sensor is incorporated into the MAF on modern Benz cars. Ignore it for now until it triggers a CEL. Is the car running normally?
Old 07-30-2013, 01:14 PM
Ivanrad's Avatar
2001 C320 Automatic
No every second random jiggle in the car like a pulley would be loose but its definitely related to the maf
Old 07-30-2013, 04:11 PM
chazman's Avatar
Unplugging MAF sensor & test drive - that's a common method to check whether the MAF sensor is the real culprit or not (on other brand cars but not sure about MB). The ECU should use the some kind of default setting when the MAF is unplugged.
With the MAF sensor unplugged:
If the car runs better than before, it means the MAF sensor is the culprit.
If the car runs same/bad as before, it means MAF sensor is NOT the culprit. Something else is wrong.
If the car runs worse than before, the ECU is not using the default setting.
Let us know what you find out.
What kind of spray/cleaner/chemical did you use?
Did anything touch the sensor's film surface other than the liquid cleaner?
Did you clean the Throttle Body? If yes, how?
Old 07-30-2013, 05:34 PM
Ivanrad's Avatar
2001 C320 Automatic
https://mbworld.org/forums/c-class-w...w203-m112.html
What kind of spray/cleaner/chemical did you use? the same as the thread says, crc cleaner
Did anything touch the sensor's film surface other than the liquid cleaner? never touched the MAF with my fingers i even put it in a Tupperware container
Did you clean the Throttle Body? If yes, how? used white cloth that doesnt rub off on the metal sprayed it with the top quality throttle body cleaner went from dirty to polished silver i covered the computer portion with a plastic bag.
I will unplug the maf today and let u all know how it goes.
Old 07-30-2013, 06:30 PM
Super Moderator
On the 320 you can unplug the MAF & it will force the ECU onto a default MAP. It usually gives an indication if the MAF is failing.
Old 07-30-2013, 06:35 PM
Super Moderator
Are you sure that the airbox is clipped down tightly over the MAF & is sealing properly? If not this causes the MAF to surge & can give spurious codes.
Old 07-30-2013, 07:26 PM
Ivanrad's Avatar
2001 C320 Automatic
okay so i unplugged the maf and drove it it drives fine just when braking it gives a little jiggle like a hiccup. im thinking motor mounts but this would gradually happen not just suddenly right>?
going to pull the codes and will check air box
Update* 15 mins ago i checked how its seating on the maf properly . it sure is... do you think its the throttle body?
Old 07-30-2013, 07:36 PM
Ivanrad's Avatar
2001 C320 Automatic
http://imgur.com/TRZaKYd
new check engine code
im just trying to understand what I could have done wrong I reinspected it again all connections are in the write order. I am thinking of taking it all apart again. Is it possible the maf was inserted backwards from what I remember its impossible .
Old 07-31-2013, 12:41 AM
Ivanrad's Avatar
2001 C320 Automatic
https://mbworld.org/forums/c-class-w...2002-c320.html
Old 07-31-2013, 08:29 AM
Super Moderator
https://mbworld.org/forums/c-class-w...ling-c320.html
You might be heading for a MAF replacement. Check everything you touched for air leaks.
Old 07-31-2013, 12:01 PM
Ivanrad's Avatar
2001 C320 Automatic
Wait how am I headed towards a maf replacement when the maf was unplugged yesterday and the car ran the same way. Where r u these evil vaccumm lines
Old 07-31-2013, 12:10 PM
SPONSOR
FYI
cleaned my MAF and air filter re oiled it with minimal oil K&n, cleaned the throttle body. NIGHT AND DAY difference car is smooth off the line no more hard shifting. I even reset the throttle calibration my holding the pedal to the floor and resetting it. Amazing results here if anyone wants pictures i will post later on. This is by far the best mod
K&N filter oil is great for damaging - wrecking the MAF.
Old 07-31-2013, 01:46 PM
chazman's Avatar
Even if you apply very slight amount of oil on the filters only enough to trap dirt but not so much to drip onto the MAF?
Quick Reply: Maf and throttle body clean w203 m112
