Easy active TPMS retrofit
#77
CAN Block
I had a few hours to work on my TPMS retrofit. I have completed most of the tasks, but I ran into an issue with connecting to the CAN block under the dash. I found two posts in the thread that discuss this issue.
Jakes states, "The CAN block. Unsnap the corner closest to the tire, it is on a weird angle...but that end with disengage and allow the block to pop out. Disengage the lower holding tray. Now, you will see to use a small trim stick, or rounded tiny screw driver and "open" the slot tang you want to snap the CAN wire end into - you do not just plug it in. You have to "open" it."
dmarciano provided some additional information, "The canbus hub is sliced sidewards to be removed and then to insert the new plug you have to remove some guard it has, be careful I broke mine and I had to fix the plastic with my soldering iron before getting it back there."
Will someone who has done this work take a look at the attached photos and provide a bit more detail on how to prepare the CAN Block to accept the connector. I tried everything I could think of and feel like I am missing something basic. I stopped before I broke anything, but I would like to complete this work soon.
Thanks in advance for your assistance.
#78
You are almost there, you see on both sides you have a lock on each? You have to carefully release those locks and you will be able to plug your connector once that is released, then you just lock it back and and slice it back where it should stay
I think I have one at my man cave because I got two from a crashed c230 some time ago to replace my broken one, so I can make a short video releasing the lock in a few days.
#79
Thanks for your reply - and your caution about possibly breaking the part. I hope you have an opportunity to post a video because I tried every way I could think of to open the block without success.
I won't be able to work on this again until the weekend. For now, I'm guessing that I will need to pull the locks away from the block. I tried that, but I was afraid to use too much force.
#80
I’ll double check as soon as I can for images or better notes.
I recall (similar to fiber optic connection ends) it fought me at first...but then it’s really simple to release the snap and it slides out.
I may have a spare one as well as I recall buying CANblocks to bench test for possibly this and other retrofits...
You’re almost there!
#81
If I've learned one auto-repair lesson, it is: If you are using a lot of force, you are probably using the wrong technique or something is about to break.
I'm glad I have the option of asking for help on the forum. It made it easier to stop and ask for help before I broke something.
#82
I feel the same way, parts are designed to work as designed...
I recall there being a bar/tab to release then you can add to the distributor block. I also remember messing with it longer than I thought appropriate- then, pop, it unlocked with not too much force...
I have worked under the dash...
but my TPMS harness is connected under the threshold...image attached...so if you don’t want to be uncomfortable on your back, try that location...there was one small “loop” to feed the wire thru at or near the base of the B pillar FYI if you want it all routed and in OEM channels.
I only have a CAN C distributor loose as pictured...
#83
Found this picture of the CAN Block
Open CAN Block
The picture is small and loses detail when I enlarge it. However, based on what I can see, it looks like the CAN block opens by pushing the two ends out and then away from the block.
I'm planning to make another attempt on Sunday afternoon.
#86
I completed the connection to the CAN Block
Jake's photo and instructions were helpful. I also found these instructions which provide another option:
To detach connectors the block cover has to be removed. Insert a flat head jeweler's screwdriver to lift the latches on each side. It helps when you use masking tape to tape the screwdrivers to the side of the block to prevent the jeweler's screwdrivers from falling off. Then gently pry off the cover (upward) with another small flat head screwdriver. It's better to pry off from one end and then the other.
This photo shows the two parts of the CAN Block:
As usual, it was simple once I determined the correct method. My only true skill as a mechanic is persistence.
I dropped off the programming instructions at my independent mechanic's shop on Wednesday. He told me that he should be able to use his STAR system for the programming. I also need to have a tire pressure sensor put into the right front tire. (That sensor failed the day after I had my new tires installed.)
I feel like I am on the home stretch.
#87
Today for the first time, and for the very reason I installed this, it kicked up a warning.
I was about to go up onto a local freeway with my 6 year old daughter, but this tripped about a mile before hand...I had time to get home.
I’ll investigate later when tires normalize...
#89
I put my TMPS retrofit on hiatus while dealing with other more pressing matters. In the interim, another board member (Jake/BF_JC230) and I picked up a STAR diagnostic system through an auction and I decided to tackle the coding myself. Here's an update.
Mercedes built my car in September 2004 and that may affect the outcome of this project. I followed the instructions on the initial post (TPMS in DAS - Step by Step). When I arrived at the instructions on page 4 of the document, I found that my menu did not have an option for "Tire Pressure Monitor." Instead, I have a selection for "Tire Pressure Loss Warner."
I'm planning to change this setting from "Not Present" to "Present" and see if that will give me a warning if I change the air pressure in one of the tires. This would be similar to what Jake reported in the last two posts.
I would appreciate any feedback before I make the change. I would like to avoid doing any permanent damage.
#91
Based on my (and assuming your) EIS, we can't show actual values as the amazing originator of this post has.
I (we) can only have active Low Line.
But, as said, it did warn me before about to hit the highway with my six year old...so, I’m okay with that!
I’ll check notes soon...
#92
Yes, set to present and the walk back out gracefully, following the prompts...don’t take a shortcut out of the programming.
“Without”
and here’s my EZS
“Without”
and here’s my EZS
#94
It looks like you have a W211 - but in my 2005 C230K Sport Sedan, no hardware was needed for the basic system. A fellow member on here simply coded my car for it and it worked for the rest of the time I owned the car. I saw the warnings like shared above several times due to tire pressure issues. This was 10 years ago now. My 2005 had a build date of 1/25/2005.
Pics are from 2011.
Pics are from 2011.
#95
Thanks for the replies. I won't have time until tomorrow night to use DAS again - it is time to celebrate Mother's Day. (I spent an hour fixing my front SAM and asking for more than one victory a day may be pressing my luck.)
#96
I’ve re-read this thread and I think the challenge I am facing is that my car can support the tire pressure warning system, but not tire pressure monitoring. Based on some pages that came up when I searched on the term “Mercedes tire pressure warning” and LILBENZ230 comments in post #94 I didn’t need to add the tire pressure monitors or the module I connected to the rear SAM and the CANBUS.
I think the system I can activate works by using the anti-lock brake sensors to determine whether any wheel is turning more rapidly than the others. A tire that loses air has a smaller circumference than the other tires and it revolves slightly faster. The system reads this and sends a warning. It is not as precise as the TPMS that the original poster was able to activate, but it may save me from getting on the highway with a tire that’s about to fail.
#97
I cannot see actual values either, like LILBENZ230, but, I believe my system is utilizing the hardware.
Not only was it coded and accepted by DAS, it knows when I change summer and winter tires.
Just something to think about.
I never analyzed a real time reading, but, I do know where the air pressure threshold was set...
#98
I changed the setting to the one Jake shows in post #93. I will be driving the car to work tomorrow and I will report on the results.
Friday or Saturday I will be performing my monthly tire pressure checks on my fleet of four cars. I expect that I will be adding a few pounds of air to at least one tire. I'll be interested to see whether that triggers a warning.
Like Jake, I have tire pressure monitors in each tire and the receiver is hooked into the wiring. If someone with a car of mine and Jake's vintage (2005 or earlier) is starting this project, I recommend that they see what happens if they change the "Tire Pressure Warner" setting to present before installing the sensors and receivers.
#100
I didn't have any warnings or messages on my commute today.
I think the system that Jake and I have is an indirect system. See this article for a detailed explanation: Indirect TPMSThe article includes a list of cars with indirect systems:
Indirect TPMS applications include:
The OP had a 2007 C350 and it appears that Mercedes was in the process of changing over from the indirect to the direct systems during that time period. The direct monitoring systems must be more expensive to install, so Mercedes may have used an indirect system for as long as it could.
I'd like to be able to figure out how to add the direct TMPS. That would appear to require an update to the EZS-Electronic ignition switch module. I would need to know a lot more about that module before I made a major change to it.
- Mercedes C-Class 2007
- Mercedes SLK 2005-‘07
