Bad vibrations at high speeds(new problem for me)
I was going 90 MPH on a very good highway. It wasn't the road quality.
I've gone 90 mph many other times with no vibrations whatsoever(and faster, for that matter)
My idea of causes-
4 months ago, I had the inside part of the bumper(the part that covers windshield wiper fluids) become undone and I had to tear it off( see here). This was the 2nd time that I had gone such speeds without the cover. The first time I had no problems AND I had 2 other friends inside the car with me. For now i'm ruling that out.
My suspension is going to s**t...shocks? struts?
Does anyone have any info on what was happening? Sunny day... not a spec of water... I glanced at all the wheels and tires when I reached my destination and it all looked fine(i'm not going to check pressure when tires are hot).
For reference, I've gone 87-88 MPH countless times since then and never had a problem at all. I watched the speedometer, too. 85 mph? perfect. 87 mph? perfect. 89 mph? great. 90 mph? OH f*** what is happening!?
Thanks in advance.
edit- I can't really describe the vibrations as that was the first time I've experienced the problem. The most accurate thing I can compare it to is going over the shoulders rumble strips... but if they were more spaced out. And if they poked above the surface...
If you are thinking it's just a flapping body panel, then have someone drive in front of you and look.
If you suspect a mechanical component ...
* balance tires?
* struts/shocks are a big one
* in the front, control arms (bushing or ball joint end) or upper strut mount
* flex disks on both ends of the drive shaft
The simplest one is tire balance.
I would also suggest checking those flex disks immediately ... if they are excessively worn and the driveshaft is starting to wobble, you are in for a major accident and auto repair if one of those gives out.
How many miles on the car, and what has been replaced already?
And another option ... don't drive 90 mph!
Had a slight hint of vibrations starting at 75 (74 was ok).
Then at 80 it's like driving on a wash board.
Rear tires were just a bit off balance
Also, if the steering wheel is vibrating, it's the front tires/shocks/whatever.
If you feel vibrations under your butt, it's something in the rear.
The brake lever arm is exposed to dirt, spray, salt etc and eventually the arm gets stiff and does not return when the brakes are released. The culprit is the rivet bushing with is a very poor design.
I free'd mine up a couple of years ago first by using some PB Blaster to free it then using anti-seize as a lubricant - use a lot of it and coat it, grease will only be a short term fix as I found out the first time I tackled the problem a year before.
I am now on to 5 years without an issue
go check out these related posts:
https://mbworld.org/forums/c-class-w...l-bearing.html
https://mbworld.org/forums/c-class-w...on-rumble.html
* balance tires?
Rims have a few scuffs but otherwise fine. Speed limit is 65 mph but I've never seen the flow of traffic go under 73 mph.
I free'd mine up a couple of years ago using anti-seize as grease will only be a short term fix.
Thanks to all for the responses...at least now I have an idea of what to inspect(and research as I have nearly no idea what a flex disc is). I just found it weird, though, because I go 80 mph every day and never had this problem and today I just so happened to leave my foot down a little longer than usual
The arm in question:
Maybe a brake fluid flush is in order, especially driving above the limit
So you have been driving for about a year +- ?
I kinda suggest that you slow down a bit
Also make sure that one of your under-chassis cover panels isn't loose and vibrating.
