Confusion over H&R Cup Kit
Subscribe
Nov 19, 2003 | 12:40 AM
I have noticed alot of the members in this forum are using the H&R cup kit. I have been making some enquiries into lowering my car further (I currently have eibach springs in) from 2 fingers.
Does anyone know how much lower the cup kit could bring my car down? Would I be able to bring it to the point where my tyre is just under the lip or even lower?
Anyone recommend other cup kits?
Reply 0
Nov 19, 2003 | 01:10 AM
if i remember correctly, cup kit lowers 2.0" front and 1.4" rear...
search for cup kit in the forum... i'm sure u'll find lots...
Reply 0
Nov 19, 2003 | 02:02 AM
Hi, what would be a softer ride (less bouncy/more comfortable) and least likely to bottom out with 3 adults in the back--coil overs or cup kits? Any response would be greatly appreciated. Thanks
Reply 0
Nov 19, 2003 | 02:09 AM
only advantage of coilovers are that they're adjustable, but i believe the ride is going to be a lil bit harsher, but will outperform the cupkit...
Reply 0
Nov 19, 2003 | 02:18 AM
Quote:
I thought the cup kit is a coil over?
Reply 0
Nov 19, 2003 | 02:32 AM
Re: Confusion over H&R Cup Kit
Quote:
I dont think you can lower to that point for the front part,..the front part will be much higher, thx
Ab-ab
Reply 0
Nov 19, 2003 | 06:35 AM
I'm using Cupkits right now and I'm not really satisfied, the front still have a gap between fender and my tires.. but the ride is very comfortable..
In 2-3 weeks maybe I will sell mine if you interested.. : )
Reply 0
Nov 19, 2003 | 07:28 AM
I think the only thing different between cup kit and coilover is that coilover is height adjustable. I've used to have Eibach springs on my car, now I'm using H&R Coilover and I couldn't be happier, the car now corners flat as a pancake and the ride is better than I thought
Reply 0
Explore
Nov 19, 2003 | 09:39 AM
Quote:
Were you using the sport eibachs or the pro kit? Mine I believe is the pro but its just not low enough.
The cup kit is supposedly twice as low is this true? Thanks for the help
Reply 0
Nov 19, 2003 | 12:18 PM
So you're saying you can adjust the height of the coilover so the car is as low as you want? I assume there's only a certain range you can work with. My thing is that I like the stock height in back, but want to lower the front a bit so that the space in the wheel well is the same as the back. I'm not sure if the coilover would be the right thing, or if I'd just be better off cutting the springs.
Reply 0
Nov 19, 2003 | 02:04 PM
Cutting the springs is always a stupid idea. You can't tell what the spring rates will be after you cut them. If they match, you are incredibly lucky.
Lowering one end of the car is not a good idea, because you are changing the relationships between the front and rear roll angles.
Reply 0
Nov 19, 2003 | 02:28 PM
I don't know what you mean by "spring rates", but I'll take your word for it. I always thought that it was very common to cut springs to achieve the desired height?
As far as lowering one end of the car, what about those who lower the whole car but the front is lowered more than the back so that the space (or lack thereof) in the wheel well is proportionate? Doesn't this have the same effect?
Reply 0
Nov 19, 2003 | 02:53 PM
Cutting springs is very the bad! It makes you go bouncey bouncey bouncey.
One of the guys I know is using a coilover kit on his car and it is very very very low until his bumper scrapes just about everywhere.
Reply 0
Nov 19, 2003 | 02:58 PM
can you show us the picture? I really want to see how low H&R Coilover can go.. Thanks..
Reply 0
I definitely don't want that!
Reply 0
Nov 20, 2003 | 01:09 PM
The car that my friend is using is a HSV (aussie car) not a merc but I can take a picture for you if you would like.
Esputmono let me know when your planning to sell I might be interested. The coilovers would be lovely but they just seem to dam expensive.
Reply 0
Nov 24, 2003 | 02:05 AM
Quote:
Sorry for the late reply. With H&R CO you can lower the car from 1" to 2.2". Right now my front has only 1 finger gap and I believe I can lower the front for another 1". The rear tyres are tucked in 1/2 a finger and I can also lower the back for another 1".
I don't wanna lower the car to the max as I don't want to compromise the ride quality.
Reply 0
Nov 24, 2003 | 02:15 AM
esputmono.. u can see mine ?
Reply 0
Nov 24, 2003 | 02:26 AM
So the LEAST it would drop the car is 1" in both front and back? An inch or 1 1/2 inches would probably be perfect in front, but I don't really want to drop the back at all.
Reply 0
Nov 25, 2003 | 07:10 PM
Back to cutting the psrings, the car cannot be aligned once the springs have been cut. Plus it's rather dangerous. You're right, it is very common, but very stupid in the same right.
Reply 0
Nov 25, 2003 | 11:27 PM
Here's a pic of cup kit if you guys are interested..
My CLK dropped with cup kit.
Reply 0
Subscribe
Currently Active Users (1)
