Has anyone figured out the thumping from the rear of the car? (03 C230k)
Old Nov 21, 2003 | 08:38 PM
czachari's Avatar
2003 C230
Mine still does it after running it hard for a few minutes and then stopping with the engine idling at a light or something. Sounds really bad inside the car but it's almost inaudible outside the car.
CZ
Old Nov 21, 2003 | 08:42 PM
jpb5151's Avatar
So far, the only thumping I've gotten after driving hard was from my wife...
Wish I could help, but our sedan hasn't done that. What did the service people say?
Old Nov 21, 2003 | 09:24 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
It's not the Bass BOSE gives you...
Erik
Old Nov 22, 2003 | 12:20 AM
TNblkc230wz's Avatar
C320 Coupe
I've never heard any thumping from mine
Old Nov 22, 2003 | 12:57 AM
daimaru's Avatar
My 230K sedan does the same thing, although it sounds more like "blooob blob blooob blooob blob". My vechicle makes this strange noise occasionally after it comes to a complete stop. I believe the sound is coming from the rear right area of the vehicle, probably somewhere below the right rear seat...
Old Nov 22, 2003 | 01:22 AM
levelr123g's Avatar
my c320 also does the same thing. I think it is the gas sloshing around in the tank, as ive noticed that when the tank s full, it doesnt do it, but when it is at 1/2 or less it makes this sound. go figure?
Old Nov 22, 2003 | 09:40 AM
jrct9454's Avatar
'14 GLK250 Diesel
Check the previously published list of C problems and service bulletins. This sounds suspiciously like the fuel purge valve problem...check with your dealer.
Old Nov 22, 2003 | 04:04 PM
czachari's Avatar
2003 C230
John, can you be more specific as to where I can find the Purge valve service bulltn?
To be more specific the noise sounds something in between someone in the trunk hitting the back of the rear seat with their fists, or the muffler backfiring like "pop, pop, pop". It's definitely NOT gas sloshing around since it happens every time I run the car hard and then stop and idle regardless of amount of fuel in the tank. From the outside, the sound is very subdued more like tick, tock metallic sound and it seens to eminate from right infront the rear axle area. Inside the car the sound is amplified to a thump/pop.
After I stop and idle I hear it within a few seconds and I only get between 3 and 7 thumps/pops. After that it's quiet.
Sincerely
CZ
Old Nov 23, 2003 | 03:46 PM
mctwin2kman's Avatar
I have never had it happen. The only thumping I get is when I slide around a left hand corner and the rear sway seems to sound like it is rapping against something. Dealer could never find it and it only happens when I really am pushing it hard as I slide around a corner, it has to be a left, does not do it going right.
Old Nov 23, 2003 | 08:09 PM
Outland's Avatar
2002 C230 Coupe(M111)
Re: John, can you be more specific as to where I can find the Purge valve service bulltn?
Sincerely
CZ
Why not pull down the seats and sit back there while a friend drives?
Old Nov 23, 2003 | 08:13 PM
czachari's Avatar
2003 C230
Outland, my back seats don't fold ( I think )
I thought the 60/40 split was optional. Right?
CZ
Old Nov 23, 2003 | 11:31 PM
Frank B's Avatar
2003 C240 4matic
I have a 2003 240 4Matic and get a thumping sound "thump. thump, thump, from the trunk sometimes. Sounds as if there is someone in there trying to get out.
I think some cars have two gas tanks that are connected. If so, and if my does, I wonder if it could be noise from the pump moving gas from one tank to another?
Old Nov 24, 2003 | 09:55 AM
jscavo's Avatar
w203
'02 coupe
i have the same noise under the same conditions. thought it was the bose bass box in the rear and the HU noise volume adjust. But I unplugged the bass box and drove around for a few days but still heard it. I also found out that the trunk floor above the muffler gets warm after driving for awhile and then stooping (heat rises). maybe its the heat and material exspansion (rubbing) that is making the noise once stopped at a light.
Old Nov 24, 2003 | 12:53 PM
Kompressor4u2nv's Avatar
What sedans have the option of fold down rear sears? I have a 2004 c230k, and I was thumbing through the quick manual, and it has a picture of these two handles in the trunk, and I went to look, and it seems I don't have them :p
I haven't heard the thumping either.
Old Nov 24, 2003 | 01:26 PM
Taiwanese's Avatar
2003 C230
I have the same sound, too. It's more like metal clicking sound. It happens while opening rear right door. Maybe the spring or something.....
Old Nov 24, 2003 | 07:16 PM
czachari's Avatar
2003 C230
The floor idea sounds plausible
But this thump noise happens within a few seconds after stopping. Also, I don't think it happens if I stop and turn the ignition off. It only happens after I stop and idle....
Weird.
It's really embarassing when I have passengers. Even my 4 year old daughter is asking what's up with your car daddy?
CZ
