2006 C230 Sport - Jacking w/o Stock Jack?
Old Apr 9, 2014 | 12:17 PM
smoknz28's Avatar
2006 C230 Sport
Question 2006 C230 Sport - Jacking w/o Stock Jack?
I'd like to know how you all are jacking up the front and rear of your vehicles without the use of the jack that came with your car.
I'll be venturing into replacing my brake pads and need to jack up the vehicle...obviously....to get the wheels off.
I don't want to damage the body, chassis or any other part under the vehicle.
Thanks.
Old Apr 9, 2014 | 12:51 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
In the front, there's a plastic puck dead center of the underbody cladding - you can see it. Put your jack there, then use stands in the jack positions on the sides of the car.
For the rear, I use the diff housing to jack from.
Old Apr 9, 2014 | 01:17 PM
smoknz28's Avatar
2006 C230 Sport
Thank you Tommy.
Once my wife makes it home...I'll give a visual to locate what you're referring to.
Old Apr 9, 2014 | 07:59 PM
samaritrey's Avatar
Super Moderator
THE C350
They are very obvious personally I use a hockey puck with the jack to help spread out the weight a little on the rear dif.
Old Apr 9, 2014 | 09:33 PM
tommy's Avatar
You should have that OCD looked at, Trey.
Old Apr 9, 2014 | 09:59 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
For probably forty years I've never worried about putting a car on four jack stands but when I was getting the blocks for the jack points from reverselogic.us (if you are interested in getting some, you may have to contact them as they only seem to list jack pads for use with a floor jack rather than a jack stand. If you don't, you will have to get or make something if only a piece of wood to fit in the jack point), he warned me not to do it (I do recommend his blocks for using stands on the car). Well, I see his point so I use ramps under the rear wheels and stands under the jack points in the front (jacking up the car as Tommy describes). I still think it's a bit overkill, but I also believe it's safer. You might want to consider this.
Old Apr 9, 2014 | 11:01 PM
samaritrey's Avatar
Super Moderator
THE C350
If you saw the way my jack contacts the diff you would understand... or maybe I am crazy but it helps me sleep at night
Old Apr 10, 2014 | 04:03 AM
smoknz28's Avatar
2006 C230 Sport
Thank you.
I did check out the referred to website and will be in touch with them to hear what they have to say personally about their products specifically to my model.
I think in the end though, I will opt for making something on my own. Just still at this point I'm worried I may damage the vehicle.
Man, I remember the days when you didn't have to word so much where you raised you car from....
Old Apr 10, 2014 | 08:38 AM
ncmudbug's Avatar
So do I but those days are long gone now.
Reverselogic makes aluminum blocks with detent sort of things to hold then into the jack point while you arrange stands. A block of wood with a loop of duct tape would be the cheap way of doing it. Of course, there are lots of ways to skin that cat.
Old Apr 10, 2014 | 04:50 PM
Khan28's Avatar
2012 C300 Sport 4MATIC (current) 2006 C280 Elegance 4MATIC (sold)
There are lift points at the front and sides of the car made of rubber. I've never jacked up the rear but I probably will take into consideration what Trey does if I ever have to. I use a 2 ton jack when I'm doing an oil change then use 2 safety stands that go on either side of the car. I don't trust that jack that comes with the car but I did play around with it one day and it did operate very smoothly lol.
