AC button stuck on off '02 C230
Old Jun 14, 2014 | 08:46 AM
petercrase's Avatar
2002 C230, 6 Speed, Bose Stereo, 6 CD Changer
Dealer wants $530 to repair AC button that is stuck-on "off"on my '02 C230. There must be a better way! I have about 230,000 miles on this 6 speed manual transmission model I bought new in 2002. Stockton Ca.
Old Jun 14, 2014 | 08:21 PM
Glyn M Ruck's Avatar
Super Moderator
When you say the button is stuck on off what do you mean.
That the button is broken?
That the aircon won't switch on when you push the button?
The first thing you have to do is make sure that the aircon system is fully pressurised with refrigerant. If pressure is low the A/C won't turn on to protect the compressor. Their is a pressure/temp switch in the lower condenser.
If the switch itself is damaged then the only way is to replace the dash controller module.
Old Jun 15, 2014 | 12:57 AM
petercrase's Avatar
The button labeled "EC" essentially turns the compressor off and on. When the button is lit "red" the compressor is switched "off". Pushing the button turns off the red light and switches on the AC compressor. Mine stays red constantly, therefore the AC compressor cannot come on. The AC was blowing cold prior to switch failure. The dealer diagnosis:
a/c pushbutton unit
labor & programming $ 150.00
part $ 370.00
tax $ 33.30
total $ 553.30
Old Jun 15, 2014 | 10:48 AM
Super Moderator
OK ~ they want to replace the controller.
They could be right but what you describe is typical of low refrigerant pressure. Have that checked first. You can't diagnose anything on the HVAC system without correct refrigerant pressure.
Old Jun 15, 2014 | 02:10 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
And if it's indeed the switch, you can get a used HVAC panel from ebay for less than a third of the price...
Old Jun 26, 2014 | 03:05 PM
tesla6518's Avatar
SLK230 C200
I would agree with VVF I had the same problem, had the system checked and the refrigerant was low, beware though the people who recharge my system did not have the equipment to reset the fault codes so I still had the red light on and no A/C I had to go to another workshop to get it done. before you take it back from being recharged ensure the red light is off and that you have full cooling. It is easier check that they will reset it all before you agree to have the work carried out.
Old Jul 17, 2014 | 11:40 PM
petercrase's Avatar
Programming new AC control unit
I swapped out my AC control unit and replaced it with a used one. The new unit is completely dead. Does anyone know the programming procedure?
Old Jul 18, 2014 | 11:28 PM
Poppy1's Avatar
2002 C320
I am guessing the programming procedure will be to take it to someone with STAR Diagnosis System/Software.
Old Jul 19, 2014 | 03:42 AM
Super Moderator
You need to get the car onto a Star.
Old Jul 21, 2014 | 10:39 AM
petercrase's Avatar
Need Star in Stockton CA
Are there any forum members in Stockton/Sacramento/Modesto CA area with a Star unit? I was quoted $90 at one local shop to program my new A/C control unit. I'm looking for a better deal! Thank you in advance! This is a 2002 C230.
Old Jul 23, 2014 | 10:15 PM
petercrase's Avatar
Replaced AC control unit
After my third trip to the wrecking yard I got the correct AC control unit for my 'O2 C230. Once I plugged it in the AC started working again. No programming was required, it was plug-and-play. The previous unit I tried was manufactured April 2003. My original unit was manufactured October 2001. My third replacement was also manufactured October 2001. That's the one that worked! Thanks to everyone for their help and input.
