New oxygen sensors and still 171 code
Old Jul 31, 2014 | 11:17 AM
Henry Bosch's Avatar
2005 C230K Coupe
Unhappy New oxygen sensors and still 171 code
Hi all
I have recently replaced a lot of parts on the C230.
2005 C230K Coupe
M271
Here is a list:
1 - All breather pipes, (even under the supercharger)
2 - Cam magnets and the harness.
3 - Maff ( Not Original)
4 - Upstream Oxygen sensor(Original)
5 - Downstream Oxygen sensor(Original)
My problems are as folow:
1-Even after replacing everything I still get a 171 code( System Too Lean Bank 1)
2-My upstream oxygen sensor has a voltage of 1.508v and sometimes changes to 1v or 0.980v
3-Short term fuel trim runs on 0% and sometimes runs into negative
4-Long term fuel trim stays at 25% and does not even move
Is my ECU stuffed? or is there something I am missing?
Old Jul 31, 2014 | 11:27 AM
BigN8's Avatar
2005 C240
My bet is a vacuum leak.
double and triple check all hoses
Old Jul 31, 2014 | 11:49 AM
2005 C230K Coupe
No vacuum leaks, checked all.
Old Jul 31, 2014 | 02:40 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Non-original MAF sensor is suspicious. I am not sure aftermarket ones work on these engines.
Old Jul 31, 2014 | 03:17 PM
BigN8's Avatar
2005 C240
That is my second guess also. MAFs are not all equal.
Old Aug 1, 2014 | 03:06 AM
2005 C230K Coupe
That is true, but even when car is not running the reading stays at 1.5v. When I start even if the Maff is not doing the Job original does, should the volts not change on oxygen sensor?
If the ECU was faulty a lot of other problems would be visible? I can not imagine that just this one fault keeps coming up. Could I have a leak or fault on my injectors?
Old Aug 1, 2014 | 05:11 AM
cm60k's Avatar
I don't think M271KE got MAF, it has "2" intake pressure sensors, isn't..?!?
ZAYED,,
Old Aug 3, 2014 | 04:34 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Any leaks in the brake booster? I just replaced mine for this, and finally after doing what you did, passed CA smog.
It was hissing you could hear it....
Old Aug 4, 2014 | 08:29 AM
2005 C230K Coupe
Hi, I will have a look when I get home. Would the brake booster make me use more fuel? This fault finding takes a lot of time. I don't mind but its cold over here so hands suffer.
