Annoying problem! Any idea are apperciated😊
Old Dec 12, 2014 | 09:50 PM
BlackDiamondz's Avatar
2005 mercedes c320
Hello mb drivers,
I own a 2005 c320 4matic. I had the car for 6 month. Ever since I own the car the esp malfuction displays in the center dash message screen. I've noticed when i turn the key to the on position, there is no ESP icon present. Also the esp button does nothing (doesnt light, no beep, no esp icon.) There are no other warning lights or icons. What can possibly be the cause of this and how can i fix it. Thanks
Old Dec 14, 2014 | 01:48 PM
2005 mercedes c320
Bump... Anyone??
Old Dec 14, 2014 | 02:35 PM
Cruel-Merc's Avatar
2009 C350
Originally Posted by BlackDiamondz
Hello mb drivers,
Check the ESP fuse or it could be a faulty ESP...then you have to change it all.
Old Dec 14, 2014 | 08:27 PM
neurodave's Avatar
2001 C320 w/ Sprt Pkg
Could also be the sensor by the wheel hub, or the wheel hub itself.
Old Dec 14, 2014 | 09:35 PM
kanadian's Avatar
c240 2002
message deleted
Old Dec 15, 2014 | 09:04 AM
Glyn M Ruck's Avatar
Super Moderator
Wheel sensor, Yaw sensor in trunk bumped by something & needs re-plugging. Difference in rolling circimference rear wheels to front wheels exceeding 2%. Many possible reasons.
One common reason is corrosion in the ESP harness plug. Unplug & clean with switch cleaner. The ESP module is mounted on the face of the ABS block.
Old Dec 29, 2014 | 03:31 PM
2005 mercedes c320
Thank you. I will try all the above. I'll let you know if it helped. Thanks for the pictures Glyn my ruck��.
Old Dec 29, 2014 | 03:32 PM
2005 mercedes c320
Where would I fine the esp fuse? It doesn't say on the fuse diagram
