Why is this happening with my 01 C320
Old Mar 16, 2016 | 09:02 PM
AshleeeyC320's Avatar
2001 Mercedes Benz C320
- my car vibrates violently when in any gear besides neutral.
- I have 2-3 different ticking noises that come from my dashboard when I turn my car on, then it stops after about 5 minutes
- the car jerks hard when I speed up after already going a decent speed (above 30).
- it squeaks really loudly when I'm going over speed bumps or driving over a bumpy road but only when I'm going slow??
- I've noticed that after I park that there's a small amount of smoke coming from my car and it's literally only from driving around town.
I just want answers or maybe suggestions as to what these problems could be. My dad (who pays for my maintenance) won't go to any other mechanic besides my ****ty one.
Old Mar 16, 2016 | 09:14 PM
kanadian's Avatar
c240 2002
Motor mount . Transmission mounts. Can cause the violent shaking. Lots of studd can cause the jerking gears like valve body issues
Old Mar 16, 2016 | 09:37 PM
Thank you so much.
Old Mar 18, 2016 | 08:41 PM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
The "violently when in any gear" might be the rubber doughnut the connect the drive shaft to the rear differential.
NP
Old Mar 20, 2016 | 12:35 PM
Russell Ormerod's Avatar
not a merc
Turn the radio up for the rattles
Old Mar 20, 2016 | 02:43 PM
akssdd's Avatar
2006 C230 Sport Sedan
NP
Those are the driveshaft dampeners. Should be one at the transmission and one at the differential.
OP you would need to get up under the vehicle and look at them to make sure they aren't cracked/rotted. I just replaced mine on my 06 C230 but they weren't too bad.
Old Mar 23, 2016 | 03:56 AM
Cars currently in shop for my mounts to be fixed, the oil leak to be fixed & gasket to be checked. 🙌🼠also managed to find the other dudes in my trunk that I never knew about LOL
Old Mar 23, 2016 | 08:40 AM
WaveyKat's Avatar
Something Slow
the Ticking In the Dash is the Arms that open and close the Vents for the A/C.. one or a few is broken.. and is a PITA to replace.
Old Mar 23, 2016 | 02:06 PM
kanadian's Avatar
c240 2002
you keep dudes in your trunk? On another note, that was just a suggestion to possibly send you in the right direction, i hope you had the shop inspect your mounts before replacing them because there are also Flex discs on your driveshaft that can contribute to vibration. Squeaks are common suspension bushing noises (stabalizer bar bushings)
