Recognize this (vacuum?) hose? P0171 code on 2004 C230
Old 08-17-2016, 05:26 PM
jim00seven's Avatar
2004 C230K Sedan
Hi,
So grateful for all the amazing info on this forum!
I have a 2004 C230 Kompressor Sedan and am diagnosing a P0171 code. I found a hose loose under the air box while cleaning the MAF (see pic of someone else's car, presumably with hose correctly attached). Could this be the culprit?
Cleaned MAF, throttle body, re-replaced $12 hose, changed both 02 sensors and no joy.
Before I replace MAF want to make sure not something simple. I'll Probably try vacuum smoke test next.
Thanks, Jim
Attached Thumbnails Recognize this (vacuum?) hose? P0171 code on 2004 C230-c230-vacuum-hose.png
Old 08-17-2016, 05:37 PM
ItalianJoe1's Avatar
2003 CL 600
There is a TSB on those engines for the vacuum hose that runs down to the side of the engine, the plastic connector breaks, or the hose, or a variety of pieces. You have to loosen the supercharger to get in there and replace them, but it's not a bad job, just a little time consuming.
Old 08-17-2016, 11:25 PM
jim00seven's Avatar
2004 C230K Sedan
Thanks for the reply, Joe.
Yes, i did the "easy" $12 hose, but not keen on doing the two underneath the supercharger -- Is there a DIY write up on those hoses & valve?
This guy:
did a great job of showing the hoses, but no detail on how to change them out.
I'm just hoping I can attach the loose hose(see photo i posted) to something and fix this without more time under/over the car
Old 08-18-2016, 01:51 AM
2003 CL 600
The last one I had to fix, the hose was split on the end where it attaches down by the side of the engine, between the supercharger and block. I had to loosen the blower and let it move over so I could squeeze in there and install the new hose. I don't think there's a "simple" way if that's what happened to yours.
Old 12-31-2017, 08:46 PM
Pullreader74's Avatar
2005 mercedes benz c230 kompressor
2005 C230k Hose
Hello everyone and thank you all for sharing information In this forum.
I was reading posts and found out this topic were for hoses. On my 2005 c230k I have a hose which I found it's necessary to replace. Could someone please tell me what this hose Is?
thank you in advance.
Old 12-31-2017, 11:30 PM
RWDlifer's Avatar
2005 C230K SS
That hose is part of the emissions system, and in this case what it does is irrelevant, if it need to replaced then just replace it because it has to be there....
Old 01-01-2018, 12:59 AM
Emissions system hose
Thank you for quick response.
Can you please give the part number for this Hose? Please let me know if this is something that I can do myself and if there are DIY for it.
thanks again.
Old 01-01-2018, 01:14 AM
RedGray's Avatar
2005 C230K Sport Coupe
It's a standard size vacuum hose. Any parts store, or even Walmart, will have it.
Imho, you should replace the complete hose. That hose, and others, are known to degrade and break over time.
For now, you could just get a simple vacuum hose connector, and connect the broken sections.
To fully replace the hose, I think that you have to take off the air filter housing. That can be a semi pain. Since you're not familiar with typical vacuum hoses, *I* would recommend against do that.
So, I'd suggest just getting a simple vacuum hose connector (parts store, or Walmart), and connect the two sections of vacuum hose together.
Amazon Amazon
Dorman 47307 Vacuum Connector Assortment
Price: $7.46
Good Luck!
Old 01-02-2018, 02:02 PM
Russell Ormerod's Avatar
not a merc
It's the vacuum supply for the air injection and gets its supply from just behind the throttle body
Quick Reply: Recognize this (vacuum?) hose? P0171 code on 2004 C230
