Opinion on suspension upgrade
Old Feb 27, 2018 | 11:14 PM
eric scott's Avatar
2001 c320
my 2001 C320 is in desperate need of a suspension change , I originally wanted just lowering springs but then I needed to do struts to so I changed to the h&r touring kit, but now I’m leaning on getting coilovers, anyone ever try out Bilstein b14 coilovers before?
Old Feb 28, 2018 | 01:53 AM
tjts1's Avatar
C320
Have you considered the sport suspension found on later models? It works quite well especially when paired with amg sway bars.
Old Feb 28, 2018 | 02:44 PM
Escott16's Avatar
2001 w203
it is an idea but im looking for also lowering because i have a crazy front wheel gap, and i dont belive just the sport suspension will lower it enough when compared to the things i mentioned
Old Feb 28, 2018 | 03:26 PM
tjts1's Avatar
C320
On my 02, sport suspension dropped the front 1.5".
https://imgur.com/a/OpX2E
Old Feb 28, 2018 | 03:30 PM
Escott16's Avatar
2001 w203
i switch out my wheels every winter to smaller 16" with winter tires, i feel like it may be too low if i put the sport on, atleast with the coils i can lower and raise it
Old Feb 28, 2018 | 03:57 PM
tjts1's Avatar
C320
Yeah that's definitely an advantage of coil overs. Just make sure it's very well rust proofed.
Old Feb 28, 2018 | 04:45 PM
jcb718's Avatar
C350
Good luck on the suspension project Escott16!
I have a 2006 C350 Luxury and would like to upgrade the suspension to that of sports model. What would be needed to accomplish this besides the AMG sway bars?
Old Feb 28, 2018 | 05:07 PM
Escott16's Avatar
2001 w203
is anyone familiar with the bilstein b14 on the c320? and what options do i have if the coilovers lower the car too much, my front is way higher than the rear
Old Feb 28, 2018 | 06:02 PM
tjts1's Avatar
C320
Sport struts and springs and M12 sway bar end links.
Old Feb 28, 2018 | 07:28 PM
Bx77's Avatar
2004 C240
If it helps I have B14's on my Focus ST, smooth roads they are assume, Car handles like it 's on rails.
But on the roads in the Bronx, it can be a bit jarring.
Old Sep 11, 2025 | 10:16 AM
berkesmob's Avatar
c230 sports coupe cl203
Hey I have a c230 with non-sport suspension I want to upgrade it to oem sport springs and struts, do I need to upgrade sway bar, and sway bar links or can it be stock?, would it cause rubbing?
Old Sep 11, 2025 | 03:28 PM
TimC300's Avatar
You should change out all parts if they are different. Not sure about a W203 but for W204 the front sway bar is different between the luxury and the sport suspensions. The sway bar links are the same so no need to replace that obviously unless they are worn.
