Turn signal will not engage fully
Fix rotating/loose steering column Personally I used Gorilla Glue, but some people also used set screw or similar fastener. I actually recommend the glue method. Just make sure the column is set exactly where you want it to be before that glue dries.
Steering column disassembly
Do you have the problem where the turn signal stalk no longer holds in place for continuous blinking?
The steering wheel Torx bolt defied all efforts to loosen. I tried long breaker bar, a pneumatic 1/2 impact, tapping on the nut, etc. I was about to give up when I made a run to Harbor Freight. I bought the Earthquake XT 1/2 cordless impact on sale. Best $169 I ever spent.
It blew the bolt off without pause.
The impact has the advantage of not putting much turning force on the wheel.
5
I could not find any one selling those pieces as parts even though I had dismantled the mechanism. Ended up changing the whole combo switch. Still keeping the old switch in case someone knows where to source these plastic parts.
Photos are of the worn replacement switch. In my case, the wear was in both the white plastic pieces (the notch in the hole was worn down) as well as the black "flaps" (a round cylindrical tab that engages the notch had worn down). See photos. One of the black pieces has been removed and is in the wrong place in the 1st photo.
I agree it is awfully silly to have to replace an entire switch over 4 small plastic parts. These days I've just learned to hold the stalk as required in the up/down positions. At least the stalk still stays in the neutral position.
Worn plastic parts
Worn notch
