The Truth about Netherlands Setting
Old Nov 11, 2006 | 12:03 AM
  #151
advans's Avatar
C55 ///AMG, 535xi
Originally Posted by MCONDE01
I will give that a shot....maybe I will get lucky!
make it seem like the alarm is going on and off for no apparent reason and that you are extremly annoyed and your neighbors have complained multiple times. MB will likely to replace it!
Old Nov 11, 2006 | 08:04 PM
  #152
516mbtek's Avatar
'06 CLS55 P030
Originally Posted by advans
just tell them this.
"my alarm keeps going on and off for no apparent reason."
and they'll check your alarm, and possibly "fix" it by replacing it, and then they'll put the chirp on if you ask.
they replaced my alarm. but my alarm WAS going on and off. 3 in the morning!
good idea!
Old Nov 11, 2006 | 08:05 PM
  #153
Tony Berry's Avatar
2009 Corvette Z06
Can anyone confirm that the 2003 C230K has the ability to beep when setting the alarm? I took it to the dealer last week and the service personnel had the general consensus that the 2003 CANNOT be enabled to use the alarm chirp.
If it CAN be done, I'll use WaveyCat's instructions to force the dealer into doing it. Is there also a % volume adjustment ability on the 2003?
Thanks.
Old Nov 11, 2006 | 08:13 PM
  #154
Tony Berry's Avatar
2009 Corvette Z06
At the dealer, using the MB factory handheld laptop tester, go into the car's computer system.
Go into Programs
Locate the Rear SAM Program
Locate Body
Select Netherland
WaveyCat, do you know what "SAM" stands for? Have you ever seen/held this "MB Factory Handheld Laptop Tester"? How big is it? I want to go into the dealer sounding like I've done this before. I can't afford a slip-up as my dealer will see that as a sign of weakness in knowledge and capitalize on it and not do the work.
Old Nov 12, 2006 | 04:35 AM
  #155
Moze's Avatar
13 X3 28i M-Sport
It is possible and can be done in like 5mins... Just print off WaveyCat's instructions and be like... listen *****, do this now.
Old Nov 12, 2006 | 08:41 AM
  #156
WaveyKat's Avatar
Something Slow
well the laptop i used to change my setting was a Regular IBM Laptop but it had some other type of **** hook up to it and the MB Program installed on the laptop
Pic of a SAM on ebay http://cgi.ebay.com/ebaymotors/OEM-M...48103951QQrdZ1
Old Nov 13, 2006 | 04:01 PM
  #157
Tony Berry's Avatar
2009 Corvette Z06
I stopped by the dealer this morning to see what he'd say and, as expected, he flat out said it couldn't be done. I told him I'd make him a deal... charge me the minimum service charge (which I think is $24.95) and if it works, good, if not, I learned an expensive lesson. He seemed okay with that, but said his techs were busy (like they couldn't pull away for 2 minutes). He said I could wait or just come back in the morning... I told him I'd see him in the morning.
I've have some news on this topic tomorrow... good or bad I'll report back.
Old Nov 13, 2006 | 04:12 PM
  #158
Tony Berry's Avatar
2009 Corvette Z06
I wish I could find someone with that program (that was willing to share it). If I could get 5 minutes alone with the interface cable, I could build one myself. I know someone (or several someones) with the cable AND the software, but it probably isn't in their best interests to share either with me. I certainly wouldn't be cutting into their business, but they don't know me well enough to trust me on that.
So according to the seller, it is a "Signal Aqcusition + Actuation Module" [sic]. So is it really a SAAM? I guess a look at the laptop screen could answer that. I'll try to peek while the tech is screwing with it tomorrow.
Old Nov 13, 2006 | 04:21 PM
  #159
tee_tz's Avatar
ML63 AMG
Tony you have a bad dealership - first they won't give you the new key, now they won't do the 'beep sound'... Wow! It seems like they don't want to make money (well at least not off accessories).
You need to find a new dealership!
Tee_Tz.
Old Nov 13, 2006 | 05:28 PM
  #160
Moze's Avatar
13 X3 28i M-Sport
Tony -- yea it sounds like your dealership pretty much sucks at life... Hope you get the beep, seems like you're right behind me on the same mods I'm getting... Cool
Old Nov 13, 2006 | 05:42 PM
  #161
WaveyKat's Avatar
Something Slow
come to NY and i can hook u up with the dude who did mines and he can also add some more features like Gals left in gas tank, have the foglights turn on when making,Clear Codes turns, etc..
Old Nov 13, 2006 | 06:37 PM
  #162
Tony Berry's Avatar
2009 Corvette Z06
I would love to have all that enabled, but a trip to NY with my car is a bit extreme. I would also like the ability to add the foglights to the "auto" position on the light switch. The foglights do a GREAT job of lighting the area immediately in front of my car as well as to the sides a great deal. They aren't just for "fog". I might have to do what I rigged up on my last Dodge vehicle. I wired a relay to power the foglights and powered the relay from the headlight feed. Headlights on, foglights on. Simple as that.
As for finding a new dealer, that's in the plan. I'm going to give my local dealer ONE more chance tomorrow morning. If they screw with me on the "alarm chirp" or "SmartKey ordering", I'll be going to Baton Rouge. I called the Baton Rouge dealer today and they seem quite happy to help me. So we'll see.
Old Nov 14, 2006 | 12:21 PM
  #163
Tony Berry's Avatar
2009 Corvette Z06
Update: The dealer ACTUALLY did what I asked (told) them. The service foreman came out and asked where the setting was, and thanks to Wavey, I was able to tell him. He had no idea that feature was in there.
So now I have alarm chirps! Happy day. I have noticed that the default volume level is pretty low (I guess I'm never happy). Is there a way to adjust the volume of the chirps on my car?
Old Nov 14, 2006 | 12:24 PM
  #164
mig888's Avatar
EVE
Originally Posted by Tony Berry
Update: The dealer ACTUALLY did what I asked (told) them. The service manager came out and asked where the setting was, and thanks to Wavey, I was able to tell him. He had no idea that feature was in there.
So now I have alarm chrips! Happy day. I have noticed that the default volume level is pretty low (I guess I'm never happy). Is there a way to adjust the volume of the chirps on my car?
Damn, they got you jumping through hoops to make sure things remain stock!..Which dealership is this?
flip
Old Nov 14, 2006 | 01:03 PM
  #165
WaveyKat's Avatar
Something Slow
to get the volume up high they will have to go back into the Rear SAM i can't remember actually which option in was in but i remember seeing something like 10% 20% etc i put mines on 100% its pretty loud but the beep also sounds different.. GOOD LUCK with your stealership
Old Nov 14, 2006 | 01:42 PM
  #166
MCONDE01's Avatar
2005 C230 SS
How much did you pay??? I am so jealous! I have to find time to go to my dealership.
Fight the power!
Old Nov 14, 2006 | 01:55 PM
  #167
Tony Berry's Avatar
2009 Corvette Z06
The only one in town, which might be why they are the way they are.
Old Nov 14, 2006 | 02:08 PM
  #168
Tony Berry's Avatar
2009 Corvette Z06
Crap. If I don't have an "exact" path to get them there, they won't do it. I'm certainly not going to go back to have them do JUST that... they'll probably ding me for another 1/2 hour of labor.
Thanks WK.
Old Nov 14, 2006 | 02:14 PM
  #169
Tony Berry's Avatar
2009 Corvette Z06
It'll be different at each dealer. In my case, it was a 1/2 hour job and it's $80 an hour. Normally they have a 1 hour minimum, but since it took all of 5 minutes, maybe they felt guilty. Who knows? It's about the only "break" I've gotten from them.
Old Nov 14, 2006 | 02:46 PM
  #170
tee_tz's Avatar
ML63 AMG
Well at least you got it done. Hopefully if you go back they'll just do it for you -- seem like a quick change. It must be because they are the only ones in town that they act like this. My dealership is great, because they know the next one is only 8 miles away!
Tee_Tz.
Old Feb 4, 2007 | 07:08 PM
  #171
c230_04's Avatar
04 C230 SS
Question The CHIRP FEATURE ? HOW DO I ENABLE THE CHIRP ?
I seen some cars have the Chirp Feature. How do I enable this on my car ?
Old Feb 4, 2007 | 07:10 PM
  #172
harpz's Avatar
They have the car set to te Noregian Setting (if i'm not mistaken)
  #173
c230_04's Avatar
04 C230 SS
How can I enable it ?
Old Feb 4, 2007 | 07:14 PM
  #174
harpz's Avatar
Star program or via the dealer
Old Feb 4, 2007 | 07:17 PM
  #175
harpz's Avatar
my mistake Netherlands setting
https://mbworld.org/forums/showpost....6&postcount=13
there's the link
