Removing Center Console Control Surrounds
Does anyone know the proper way to remove this without damaging the trim? To date, I have not subscribed to the StarTekInfo web site, so I don't have their information, yet.
Are these all spring clips, or are screws hidden somewhere?
My examination, with the ash tray door partially open, reveals two screws holding the bottom edge of the A/C trim. It looks like the ash tray door needs to be out of the way to get at those, perhaps by removing the entire front-to-rear center console.
Thanks for any information.
I need to know how deep under the upper switch panel before I can decide whether I can mod it or not.
http://www.xanga.com/home.aspx?user=...90&direction=n
Just scroll to the middle of the page...its not a 05 thought, but maybe its the same.
The panel that holds the climate control has 2 screws on the bottomside instead of 2 clamps (obvious to see once you have the ashtray - complete assembly, NOT just the door - out) and the top panel that holds the switches is secured with the exact same 2 screws as in the pre updated 203s. Biggest diference is to be found in the clamps that hold both panels at the radioside...seriously IT IS EASY.
greetingz,
