Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Rating: Thread Rating: 21 votes, 4.81 average.
Old Jul 1, 2003 | 12:36 AM
  #576
s14sr20det's Avatar
W463
For those of you that have the 03 Bi-Xenon Head lights
I just notice that the turn signals in the head lights are double filiment. How come? I took off the bulb and there is only one contact on socket. Is the euro head lights different? Just want to know if anyone else noticed.
Paul
Old Jul 1, 2003 | 01:03 PM
  #577
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
The wiring inseide the headlights are the same on euro and US models...the US spec headlights - however - have a different fitting with a dual filliament bulb where as the euro spec headlights have a single filliament bulb...I don't know why though (since there is only wiring for 1 filiament in the headlight)...
greetingz,
Old Aug 13, 2003 | 10:05 AM
  #578
czachari's Avatar
2003 C230
03 Bi-Xenon bulb went out and got message
I got a message on my dash "check bulb low beam (L)" so I get out of the car, look at the left bi-xenon and true, it's out. A few minutes later I got home, I switched the light switch off/on and the left xenon came back on. Should I pursue this or is it just a quirk and there's really nothing wrong with the bulb?
CZ
Old Aug 13, 2003 | 05:12 PM
  #579
SOC320's Avatar
2003 C320 4Matic
Re: 03 Bi-Xenon bulb went out and got message
CZ
I would pursue it with the dealer. Since you had the indicator tell you that a bulb was out and it was physically out, there is clearly something not right. Do it while it is still under warranty.
Old Aug 14, 2003 | 03:05 AM
  #580
gmabm's Avatar
Sometime ago, I got a "Check License Bulb (L)", I went behind to checkout and everything was ok.
Few days later, the mentioned bulb got blown. Wow, the computer can actually anticipating failure!
Old Aug 14, 2003 | 09:41 AM
  #581
Jens C320
Guest
Posts: n/a
CZ
I had the same message yesterday. I turned the car off and back one and the Xenon bulb magically worked again...I've also had the cluster tell me my right break light was out when it wasn't. I talked with a friend that has a C240 and he had the same Xenon message as the both of us and his dealer ended up replacing the entire Xenon assembly uder warranty...I'll wait until my next service and then mention it to the dealer.
Old Aug 14, 2003 | 12:44 PM
  #582
charnchon's Avatar
W203
My lights work but the automatic height adjusting function doesn't. The light is too low. It's about 5 meters ahead of my car. This happens after I have a wheel alignment. Is there any equipment under the car that does the light adjustment?
The side mirror also doesn't drop when backing up. The two was just out of order at the same time.
Old Aug 17, 2003 | 10:45 AM
  #583
Tariq's Avatar
S500 W223 2021
Thumbs up C My C After Bi-Xenon....
Hope you will like it.... Use it as Wallpaper... It might change your mind to replace the new face on your C...
Old Aug 17, 2003 | 11:56 AM
  #584
LorinserCClass's Avatar
The True OG Modded out W203
Very nice! BiXenons are the ultimate "facelift" for the C. But you didnt get the clear fogs
Old Aug 17, 2003 | 12:20 PM
  #585
Tariq's Avatar
S500 W223 2021
Thanks...
About the clear fogs i dont think i will need it if i purchase it because I am going to put C32 AMG kits on it so the fog will be diffrent i think, its kind to save money for the best...
Tariq
Old Aug 18, 2003 | 06:41 AM
  #586
Guest0001
Guest
Posts: n/a
loooks nice man!!!
Damn it if i dont find a place to get mine installed soon ima go crazy!!!
Old Aug 18, 2003 | 02:20 PM
  #587
benzz280's Avatar
Euro/US bi xenon on RHD C240?
Has anyone ever retrofit a set of Euro/US spec bi xenon headlights on a Right Hand Drive Halogen C240 before? Steve is running out of UK spec ones, so i hope to get the Euro/US spec ones from him if they will fit. Thanks for any input!
Old Aug 18, 2003 | 02:22 PM
  #588
benzz280's Avatar
Hi are those US/Euro or UK spec bi xenons? Is your C class a Right Hand Drive one? If you are in country other than US, did you have to bring your car to the dealer to recalibrate the car's ECU? Looks really good!
Old Aug 18, 2003 | 02:25 PM
  #589
benzz280's Avatar
By the way, will the bixenon headlights work without bringing the car to dealer or having the dealer recalibrate the ECU? Thanks again!
Old Aug 18, 2003 | 03:36 PM
  #590
Lynn's Avatar
US/Euro headlights will blind oncoming traffic when used on RHD cars. And you won't be able to see well either. The beam will be aimed at the wrong side of the road.
Old Aug 18, 2003 | 05:57 PM
  #591
MBenzNL's Avatar
some slow@$$diesels
bajaiman has US spec 203 bi xenons in his australian C-class...and there is someone in the W209 section who bought euro spec bi xenons for his right side steered CLK in singapore...
greetingz,
Old Aug 18, 2003 | 05:59 PM
  #592
MBenzNL's Avatar
some slow@$$diesels
definitely NOT US spec...
greetingz,
Old Aug 18, 2003 | 06:06 PM
  #593
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Agree with Lynn on this one. Sorry Steve. I wouldn't put on the incorrect lights because of how the light is thrown. Those people you mentioned are taking chances in my book, or they may be thinking of driving in a different country.
Old Aug 18, 2003 | 07:37 PM
  #594
Tariq's Avatar
S500 W223 2021
greetingz,
Steve..
What are the diffrents between US/Euro spec... & how to compare ..
Old Aug 18, 2003 | 08:55 PM
  #595
MBenzNL's Avatar
some slow@$$diesels
euro versus us spec
blueish bulb versus amber bulb
no horizontal line versus horizontal line on projector lens
more versus less lines in reflector below projector
____/ pattern versus ____--_ pattern
greetingz,
Old Aug 18, 2003 | 09:08 PM
  #596
MBenzNL's Avatar
some slow@$$diesels
...I know...
Weird/funny is that there are several US people with euro bi xenons who use the anti blinding plate inside the headlight (only to be found in euro and UK spec lights - not in US spec lights) to change the lightpattern from ____/ to ____ ...
lightpattern plate in a US spec bi xenon projector
lightpattern plate in a euro spec bi xenon projector...note the additional strip that can be moved up...
euro light pattern
UK lightpattern
US lightpattern
greetingz,
Old Aug 19, 2003 | 09:42 AM
  #597
CarlssonPower's Avatar
2002 C240
NICE! Bi-Xenons make C look so much different...
Old Aug 19, 2003 | 04:05 PM
  #598
BrabusCClass's Avatar
GL450, Sienna SE
looking good there.
Old Aug 19, 2003 | 11:41 PM
  #599
midas888's Avatar
C230
Old Aug 19, 2003 | 11:53 PM
  #600
AMG4Me's Avatar
S55 AMG
Hey Steve,
Will you ever be getting in any Eurospec bi-xenons for the coupe?
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
