Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old Sep 8, 2006 | 12:14 AM
  #1426
xkillabucincx's Avatar
02 C240
whatever and however the lighting is..its kick A$$
Old Sep 8, 2006 | 12:38 AM
  #1427
M230K's Avatar
2012 MERCEDES CLS63 AMG
see how bright 4300k hid lights are, if you get 6000k or any higher you wont get the same output it'll just be more blue, i think your the same one who put out a poll about changing your fogs to a certain temp. i think you should get 4300k to match the OEMs xenons. that'll light up the road perfectly .. not that it isnt right now
Old Sep 8, 2006 | 12:48 AM
  #1428
14cue's Avatar
05 C55
you know what they say, "once you go bix you cant go back".
Old Sep 8, 2006 | 01:07 AM
  #1429
white_w203's Avatar
is SOLD
bixenons is a must for an oem mod
Old Sep 8, 2006 | 01:23 AM
  #1430
Jason.Bare's Avatar
"A Mercedes-Benz product"
The pattern should look like this:
__________/___________/
Old Sep 8, 2006 | 01:37 AM
  #1431
powa's Avatar
C320 Coupe
huh i don't understand, got a better explaination? =P
Old Sep 8, 2006 | 01:38 AM
  #1432
powa's Avatar
C320 Coupe
the thing is i think the OEM light is not as bright as the HID i had before, im guessing becuz the light is pure white, with little yellow tint when you see it in the car. im 80% sure my 6000k HID was brighter tho =/
Old Sep 11, 2006 | 05:00 AM
  #1433
sdsilverm3's Avatar
The pattern in the first pic is actually correct. The passenger side headlight lights up the side of the road while the driver's side headlight is lower to reduce glare for oncoming traffic. I personally hate the way it's supposed to be aimed so I adjusted both to a median level I can live with.
Do a search for previous posts regarding aiming bi-xenons and the results will show the pattern in the first pics is correct.
Also your 6000k's were most likely not brighter than your OEM xenons but rather it appeared that way. As the kelvin (color temperature) rises the lumens (brightness level) goes down.
Old Sep 11, 2006 | 09:15 AM
  #1434
advans's Avatar
C55 ///AMG, 535xi
this is why I want bi-x on my coupe! when people "high beam" me when i'm driving the 163, i let them pass, and high beam them back with the bix! muhauhahaha
Old Sep 11, 2006 | 10:22 AM
  #1435
powa's Avatar
C320 Coupe
haha! oh btw advans, the Bi-xenon high beam won't activate until evening or night time, if it's day time it will only lights up the flasher light i believe.
Old Sep 14, 2006 | 04:02 AM
  #1436
sexclass's Avatar
2007 MBZ C230
bi xenon headlamps
i have a 2007 c230 but it did not come with the lighting package im in the bay area does anyone know of any reliable place to get em installed? thanks
Old Sep 15, 2006 | 09:23 PM
  #1437
rlee02135's Avatar
2004 C32 ///AMG
Bi-Xenon Malfunction, Please Help
ocasionally, my xenons will start flashing on and off, and these warnings will show up.
"Low Beam, Left, Check Light...Low Beam, Right, Check Light"
if this happens, i pull over, shut everything down, and turn everything back on and its fine.
This will happen about once a week.
Anyone know why it is doing this?
thanks
Old Sep 16, 2006 | 09:14 AM
  #1438
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i never had that problem....
hopefully it's just the bulb....
Old Sep 16, 2006 | 09:37 AM
  #1439
jwelsch's Avatar
I just went through all this on Thursday. From what the tech pulled for my car the flashing lights is an indicator of a bad controler. Fortunately one of my bulbs exploded, which was causing this. It sounds like both of your bulbs are working at least part of the time. Can get pretty expensive especially if you replace the bulbs and it's not that.....
Old Sep 16, 2006 | 06:46 PM
  #1440
Bobby Dazzler's Avatar
2003 C32 AMG, 2003 ML270 CDi
I only get this occasionally and usually when I turn the lights on manually (not auto lights). Dealer diagnosed it yesterday as requiring a new ballast but that can only be fitted with a new bulb - ballast covered by warranty but bulb isn't. He's arguing with MBUSA to get the bulb changed for free as his bulletin says only do the two together. I'll let you know how we get on...
Old Sep 17, 2006 | 01:19 AM
  #1441
rlee02135's Avatar
2004 C32 ///AMG
i never use the auto lights
Old Sep 17, 2006 | 02:16 AM
  #1442
14cue's Avatar
05 C55
this only ever happened to me with retrofitted bix when my bix were not set to present.
Old Sep 17, 2006 | 10:27 PM
  #1443
patrick_y's Avatar
2006 E55 and 2002 E320
Like, rlee02135, I also never use the "Auto" light mode.
You shouldn't use the "Auto" lights in the day time especially if you have the Xenon lights because this may turn the xenon lights on and off repetitively when driving under a bridge or in a slightly darker area.
Xenon lights are very sensitive to being turned on and off, even more so than flourescent bulbs. When you turn them on, keep them on until you don't plan to turn them on for a long time.
This will help prolong your xenon bulb and igniter ballast life.
Old Sep 19, 2006 | 08:01 PM
  #1444
Tee_VINGT's Avatar
+ wanna have Bi-Xenon of CL203 Coupe +
I owned c200 coupe I also want Bi-xenon on my car.
I'm come from Thailand. Here's the price quiet expensive around $2000
I'd like to know everyone eles wants to sell it.
Please let me know. Thank you
Old Sep 19, 2006 | 08:32 PM
  #1445
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Contact Steve@MBenzNL.com.
Old Oct 19, 2006 | 03:29 PM
  #1446
cla 1000's Avatar
2002 C230 K, 6 speed
how much did you pay for Bi-Xenon???
I am trying to find out what would be the price range to pay for bixenon headlights. Thank you.
Old Oct 19, 2006 | 03:34 PM
  #1447
drexappeal's Avatar
I special ordered my car with the bi-x. As for price range for coupe bi-x (very difficult to find), why don't you just purchase them from Steve (MBenzNL)? Doesn't he have the coupe BI-X?
Old Oct 19, 2006 | 03:48 PM
  #1448
cla 1000's Avatar
I emailed him and he said that he does not have any, nor he will get any since they are a rare find.
Old Oct 19, 2006 | 03:54 PM
  #1449
drexappeal's Avatar
I see. Well, I guess your best bet after that would either be ebay or if someone on here sells their set, especially for the coupe (like Steve said, they're rare).
Old Oct 19, 2006 | 03:59 PM
  #1450
cla 1000's Avatar
Well yes. I will wait untill something comes up. I know flave had some but it was a few month back. I did not have the monney back then.
I will be getting the 2005 front grille from Steve tho.
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
