Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Iwasn't sure where the purple cable should have plugged in, so I left it dangling.
Where should it go?. I only had Halgoens before.
Also, I got the hign beams and the background lights to wokr, but not the low beam, even with the igniton off.
Is this to do with that purple cable?.
I'm getting the computer settings changed tomorow. Thought I'd better ask in case I need that purple cable attched .
The lights I offer(ed) are all complete, new and OEM plug&play units with possible minor flaws. Some of the first send headlights arrived with a loose (or even broken - twice) balljoint inside the headlight due to the parcel being dropped by postal service people/machines. The xenon projector is too heavy for the reflector to stand the dropping of the parcel.
I think this problem is solved by using a plastic pipe and some tie-wraps to secure the reflector and projector during transit.
greetingz,
My question is...can you hear hissing sound from the adjustment wheels??, cos since I installed the bi-xenon I can hear hissing noise from my car everytime the car stops or idle. If the adjustment wheel is on "3" the hissing sound is quite loud when the car is idle, but the noise will go away everytime I step on the accelerator. I moved the adjustment wheel to "0" and that seems to almost eliminate the hissing sound.
Also, the fog lights now have clear lenses too with a different type of bulb or reflector inside. Too bad it's still yellow light. They don't match the xenon well.
We got our first Bi-Xenon coupe today at the dealer. It is a red car which someone ordered, and it looks pretty good. I think it would look a lot better on a dark colored car, but it still looks good.
How dare you LOL J/K:p
Try to take a pic if you can
I don't have a camera, but if I can get one at work, I'll try to take some pics.
you would think it would be brighter cuz no dull lense and looks would be obviously be better, plus match bi-xenons for those who have it. bi's r still on my wish list.
would it be illegal if i just replaced the lense and not the bulb? would it be too shiny or bright?
I honestly don't know how it would look. I think the lense has something to do with directing the light in the right direction. So it might light up all over the place, instead of lighting up straight ahead down the road. This might get you into some trouble with the cops, I don't know. Depends on how much else they have going on, I guess.
That is right. You can either control the light pattern with a fluted lense or with the reflector like the projector lights. You have probably seen driving and fog lights with clear lenses in the past. These were for racing and rally and off road applications where the flood type of beam won't blind on-coming traffic.
Now regarding fluted lenses with reflector-based lights, this is not true. It is entirely possible to have this nowadays, due to computer generated free form reflectors which can pin-point the light rather accurately without having the patterned lenses. Look at just about any vehicle nowadays, be it an Accord, Echo, Toyota Tundra, and you'll see what I mean.
Heck, the high beams on the Bi-Xenons are just that! Notice the clear lenses despite no projector.
Here's my truck with Hella FF100 and FF200 foglamps. Clear lens with complex freeform reflectors
These new fogs definitely had some kind of reflector inside. It looked kinda like a little silver umbrella on the end of the bulb. I'll take another look this afternoon and see if I see anything else.
I can confirm that the '03 sedans and wagons do not have this.
