Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old May 17, 2007 | 02:16 PM
  #1726
1Lop2K5C's Avatar
C63
Originally Posted by XenonBenz
When my US Spec Sedan OEM Bi-Xenon's are pointed against a garage door, there is a very visible Yellow spot directly in the center top part of the beam pattern, in front of each headlight. See the picture below.
For all you Bi-Xenon owner's out there, is this normal???
That is normal, you will find that some will have a little more yellow than the other. This caused by the light hitting the edge of the shield along with the housing design. If the shield's edge or surface has contaminant, you will either see yellow or a rainbow effect at the edge of the light cut off. With non bixenon, I found the trick is to slightly pull the shield torward the light which would cause a more bluish light effect at the cut off edge, however I would not recommend doing this to the Bix since the shields are motorized.
Old May 17, 2007 | 04:53 PM
  #1727
XenonBenz's Avatar
2004.0 C230 Sedan
Originally Posted by 1Lop2K5C
That is normal, you will find that some will have a little more yellow than the other. This caused by the light hitting the edge of the shield with the housing design. If the shield's edge or surface has contaminant, you will either see yellow or a rainbow effect at the edge of the light cut off. With non bixenon, I found the trick is to slightly pull the shield torward the lights which would cause a more bluish light effect at the cut off edge, however I would not recommend doing this to the Bix since the shields are motorized.
Thanks for the response. I just spoke with my local MB dealer, and they confirmed that the yellow hotspots are normal. They said it's worse on the C Class than other MB models. Both sides look just as bad.
My 2002 BMW 325Ci didn't have any spots at all like that.
Originally Posted by johnand
My OEM bix don't look like that. They have a more distinct _/ pattern and the hot spot is not yellow, it is white with some blue towards the top.
Your Bi-X is Euro spec. All Euro specs have the _/ pattern. US Spec pattern is _---- The US Spec shiled probably doesn't work as well as the Euro spec in our headlight design, hence the Yellow hotspot.
At least the yellow hotspot isn't really visible to onlookers. My headlights still shimmer blue/purple.
Old May 17, 2007 | 07:47 PM
  #1728
1Lop2K5C's Avatar
C63
Actually, its not just the shields between the US and Euro version. If you compare the projector lense between the two, they are completely different in design.
Old May 17, 2007 | 08:23 PM
  #1729
XenonBenz's Avatar
2004.0 C230 Sedan
Anyone have a close up picture of a Euro spec projector beam?
The US Spec Bi-X have a horizontal line that goes across the center of the projector beam. Does the Euro spec have that line also?
I've read that Euro spec HID's are called ECE, and usually have better optics, sharper cutoff, and a wider beam pattern. Anyone want to trade?
Old May 18, 2007 | 04:25 AM
  #1730
phranksmbz's Avatar
09 c300 4matic
Oh ... sorry about this, i been procrastinating the past couple years and i really want to get this mod out the way. I started a new thread just incase others were going through the same issue. Thanks for combining them.
Whats better eruo spec or usa spec?
Old May 18, 2007 | 02:33 PM
  #1731
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
HELP! Place in So Cal to set Xenon Present
Got shot down at House of Imports Buena Park by the Service Manager, Eddie Borluca.
He said that w/o the self leveling feature that House of Imports would not put in the xenon setting.
Anyone have a recommendation?
Ed
Old May 18, 2007 | 02:42 PM
  #1732
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
can't wait to see it E!
pm john (glassjaw), he's at BH Benz.
Old May 18, 2007 | 02:49 PM
  #1733
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
you getting that Bix from group buy?? or did you ebay a HID??
Old May 18, 2007 | 02:51 PM
  #1734
Blake P's Avatar
'09 A4 S Line
gb
Old May 18, 2007 | 02:56 PM
  #1735
SeaCoupe's Avatar
I have a call in to him....
Borluca was talking about not wanting to blind other drivers because the lights wouldn't be leveled. There was not convincing him. Never mind the lights have two self leveling screws, just didn't want to do it.
I have calls in to Long Beach, South Bay, and GULP!!! my next call will be to Fletcher Jones in Newport.
Problem is, I have no pull at the dealerships because I have self serviced my car for about the last 40k miles.
E
Old May 18, 2007 | 03:06 PM
  #1736
SeaCoupe's Avatar
Brotha's hooking Brotha's UP.
Bling Boy in da Hizz ouse....
Thanks Drex, I got the hook up to get the Fooo Shizzle done!
Blingboy4eva
Old May 18, 2007 | 03:09 PM
  #1737
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Only slight differences. I see you have a sedan. Order from MBenzNL. Now, please learn how to search. All of this has been discussed several times before.
Old May 18, 2007 | 03:50 PM
  #1738
drexappeal's Avatar
Blingboy4eva
E,
I couldn't do what we had talked about at the meet. I don't have the capability to save.
Glad it worked out. Make sure we so those pics soon. BTW, might as well chat with them 'bout your error codes.
Old May 18, 2007 | 06:50 PM
  #1739
SeaCoupe's Avatar
They in.
Damn, many sox gon get abuzed 2-nite.....
Splinter came over and helped out. We did it in about 2.25 hrs. No need to completely pull the bumper off.
No DIY, others have done it better than I could. Now, out to get the xenon present setting at 5:30!!!!
Blingboy4eva <---dont worry, the attitude will wear out soon nuff....4 sho
Old May 18, 2007 | 06:54 PM
  #1740
nlpamg's Avatar
sick, take pics now!
so, now the question... did you fix your fogs yet?
you'll be blingin more when your 19's come in!
Old May 18, 2007 | 06:59 PM
  #1741
SeaCoupe's Avatar
I'll have you know, I did put in the replacement fog, but it is not the new clear lights I bought.
The new clear fogs will come in with the new grill.
E
Old May 18, 2007 | 07:01 PM
  #1742
nlpamg's Avatar
E
oh ****, you got a new grill too? daaaaamn, you ARE blingin it out! 05 or mattig?
niiiiiice.
Old May 18, 2007 | 07:11 PM
  #1743
SeaCoupe's Avatar
05 Grill.
Nice......
Dude, I keep going out to look at the car. Just have to adjust them after the setting is in. Babies are PIMP!!!!
Call me jr. PIMP!!!
Notorious B*I*G
Old May 18, 2007 | 07:15 PM
  #1744
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
I Can get it done....
Let me know...
Old May 18, 2007 | 07:19 PM
  #1745
nlpamg's Avatar
05 Grill.
Nice......
Call me jr. PIMP!!!
Notorious B*I*G
acks Drex, we have a lot of experience with adjusting the bix...
when does the rest of your stuff come in? southbay photoshoot!
Old May 18, 2007 | 07:44 PM
  #1746
SeaCoupe's Avatar
Now, where do I get the self leveling kit to finish off the install?
I wonder if Saprissa knows it?
Damn... been out to look at the car, WAY TOO much!!!
Ed
Old May 18, 2007 | 11:10 PM
  #1747
SeaCoupe's Avatar
Wow!
I'm just truly floored by how cool the look of the lights are. It is a great looking blue type light. I feel like the lights really turn the look of the car into a newer Coupe.
Got to find a way to take a night drive tonight.
Special thanks to Splinter. I owe you big my friend.
E
Old May 18, 2007 | 11:11 PM
  #1748
SeaCoupe's Avatar
Let me know...
Mark;
Much thanks for the offer amigo. I got it done by one of your amigos in the South Bay. He spoke highly of you.
E
Old May 19, 2007 | 08:11 PM
  #1749
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Nice work, E. Looks sharp! You will be front row at our next meet.
Old May 19, 2007 | 08:49 PM
  #1750
SeaCoupe's Avatar
Well, I'll be testing them out tonight. Decided to do the drive to San Fran at night.
Took a long nap today, watched the Preakness, ate, and about to take off.
Huge Thanks for the help, and thanks for posting the pics up.
Ed
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
