Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
It looks as though Bosch ballasts have been a source of concern Stateside. I can't say they have here but then we far fewer vehicles this end with Bi X.
But i have more of a feeling its probably a bad ground. Usually oem ballasts dont go bad..even bosch ones
I still remember ordering my car from Australia (3 month waiting list at that time) when I knew I was returning home and requested Bi X, Parktronic etc. etc. The sales lady said to me on the phone "Good heavens Sir - nobody orders those things - they are so expensive!"I'm not sorry!
I can buy brand new authentic bi-xenon lamps (w203 facelift model) for 1100 euros, my question now is can this be done without having to change things in the wireing etc. So at the very moment I have factory xenons (first old model) and would like to get the bi-xenons. Am I going to have a lot of additional costs in order to make this thing work? I would appreciate any suggestions...
* Lamps from car accidents (broken tabs) make good spare parts.
* Should be a direct swap.
Here in the US it's only like 50 bucks.
I posted a pdf recently on that...
What do you think are they going to charge me at mercedes if I would like to let them install the bixenon lamps??(my spanish sucks so I already asked him but he told me I dont know) + Is it possible for me to do it myself... (although I have not done anything like that, so I'm pretty much inexperienced)....
Many thanks in advance...
first, we know its not the bulbs because you swap the other side and it worked.
I strongly don't think its the wiring issue, how can it work before and stop working now?
unless someone alter your wiring.
which work down to only 1 other possible problem:
its the control unit, some people call it the ballast or igniter.
just replace the igniter and it will be fine.
if you cannot buy the same igniter, buy any ballast from a HID kit will works the same as well.
I had this done because my old igniter is too hard to find and too costly to buy.
good luck.
my 02 c-class coupe does not c/w euro bi-xenon.
it was stock halogen before
I swap the headlights, went to dealer and paid less than $50 to re-map the computer.
the code was "xenon present", works right the way.
if you want to swap your lights, you need to remove the bumper and its not hard to do.
then swap the lights, max is 2 hours for most shops.
if you DIY might be 3-4 hours
the plugs and wiring are the same.
I belive 02 and up C-class are all built-in ready for xenon.
you do not need to alter any wiring.
if you take your car to any HID installation shop, buy just 1 ballast and they can install the ballast for you. they know how to wire the new ballast to you light.
Dovla - people are talking a lot of crap to you on this thread re Europe where you have to have auto leveling by law & your car probably does not have the correct wiring harness so your mechanic is right. You have to fit & connect front sensor, rear sensor, yaw sensor & fit the microprocessor. The yaw sensor is under the back seat and part of the ESP - You are not in the USA - BiX are a menace without self leveling.
See this post of mine from elsewhere:
"All factory BiX any year have auto leveling and washers - clear lens & come with clear lens (glass) fogs. They all do a flip flop on start up to auto level due to the attitude of the car. The BiX kit was designed to meet European regulations. You may not have BiX lights in Europe without the auto levelling by law. Auto leveling = front attitude sensor, rear attitude sensor, yaw sensor & micro processor. This is because they are so bright you can blind oncoming motorists.
In the US you can get away with retro fitting them without auto leveling. In Europe, Australia & South Africa etc. your car would be thrown off the road.
I'm surprised some aftermarket guys have not devised at least a manual shutter control for BiX in the US.
If you have the time read this thread - It contains all the details amongst other things
https://mbworld.org/forums/c-class-w203/267519-my-03-c240-pics.html
The proper kit for Europe:
Because if all this is going to be extremely expensive, I think I'll just go for a new igniter/ballast... The other question than is, if I just a new ballast for a mercedes c class on ebay, does it mean that it automatically supports the auto levelling option or not? Because, obviously I have it right now, and I'll still need it of course, since I'm living in Europe...
Any ideas would help, many thanks once again in advance...
I asked him the same question, and he said it should be it because he did not see the difference and he said nobody ever did such a conversion at the benz-dealer (I called Amsterdam, Holland official benz-dealer).
Now I don't want to spend 1500$ and then to find out that it won't match. Any suggestions, just go for it or...?
It sounds as though your car has the correct harness which means it must already have the auto leveling. If it has all the stuff I've talked about above then Frank is absolutely correct & it will be plug & play. Crawl under the RHS front and look for the auto leveling sensor arm connected to the sway bar & look at the RHS rear and you can see the rear sensor connection to the lower swing arm. If it has those it will have the yaw sensor connected from the ESP as well. Then you can safely buy the Bix.
See a pic of the back of Frank's car I stole off his thread. He has modded suspension but see the thin bent connecting rod from the sensor arm in the centre rear of the car connected to a bracket on the RHS lower swing arm - looks like it's connected to the spring. This is the rear Bix auto leveling set up.
If you can't find these things I will crawl under my car and photograph for you.
I wasn't sure of what part to make pictures so I added a few pictures of my car....
To add a bit more confusion on top of all this, I went to the benz dealer yesterday and the Spanish mechanic told me that it wasn't possible. But that is again on the contrary of what the Dutch (also official benz mechanic) said. I think the Spanish mechanic didn't really use his brains besides looking in the computer what the additional options where possible to choose from when purchasing the car. Well obviously you couldn't choose for bixenons when that firstly was availible for the facelift w203.
Honestly guys I'm pretty much sick and tired of this because nobody seems (at mercedes) to really have any experience with this and basically doesn't know s*it where they talk about. The mechanic asked me why I would like to put bi-xenons on it. I mean if he is stupid, he doesn't have to be a smartass asking stupid questions.
p.s. I'm not sure what it is on the picture on the left that is kind of oily, is it something I should be worried about?
Once again, thanks for your help, really appreciate your effort. I wish they where this helpful at the benz-dealer.
It looks as though you have a differential oil leak. Likely the pinion or side shaft seals. You must have that fixed.
