mirror blinkers
2016 E63s AMG
mirror blinkers
Were can I go to get the mirror blinkers changed to white? Is it expensive to change those bulbs? Can someone please give some help? If it matters I live in NYC. Is there a place there that can be recommened
Former Vendor of MBWorld
Nothing MB related (sorry)
Pics can be found here:
http://groups.msn.com/MBenzNL/europa...o&PhotoID=2334
http://groups.msn.com/MBenzNL/europa...o&PhotoID=2379
You can get more info on www.MBenzNL.com, or email to steve@mbenznl.com.
Greetingz,
BigSis
Greetingz,
BigSis
2009 Porsche 911 Carrera S
This mod has been extensively discussed... Please do a search on "mirror blinkers" or "W203 blinkers", etc.
I personally don't like the look of the ones shown in the thread submitted by BigSis and lean more towards the ones on the new E-Series (and which will fit your car).
I've personally done this mod. It costs ~$40.00 for the parts purchased at the dealer and ~20 minutes to install ... it's a no brainer and the threads you'll find will have MB part numbers and installation pictures. By the way the new lights are white LED's that blink yellow.
Hope this helps.
Hope this helps.
1 Post
2003 Citron Green C230KMT
replace the strip with the W211 blinkers. they look great especially if you have BIX lights. they really go well. honestly LED's that blink white wont look right.
Originally Posted by ernster
there is no way just to take off the strip and replace the light? Not replace the mirrors.
2016 E63s AMG
citron
are they expensive doug? What am I looking at for the complete job done? Were do I get those w211 strips? Can you give me a link?
1 Post
you can get them from you dealer. about $75 for the pair. all you need are the indicators. they are a direct replacement in the mirror housing. you will need to modify the plug froma 4 pin to 2 pin in order for it to work. the 211 blinkers come with a bulb for the puddle light which needs to be removed. then take a 2 pin female jumper and splice it onto the remaining 2 wires. then it plugs into the 2 pics int he mirrors hhousing. make sure you get the polarities right, if they dont work the first time, unplug and plug in the opposite of how you did the first time.
1 Post
if you want the LED's to blink white, you will need to open up the strips, de-solder all the LED's and re-solder, white blinking ones. its not the hard if you know how to solder. though im not sure how easy it would be to open the indicator strips to gain access to the LED's.
MBworld Guru
white and whiter
R129, XF Sportbrake, SC400
$150+ for mirror blinkers? What is this guy smoking!?
http://cgi.ebay.com/ebaymotors/OEM-0...12378445QQrdZ1
