One-touch windows quit working...help please
Old Nov 15, 2004 | 02:37 PM
Brunelleschi's Avatar
In the market
I disconnected my battery over the weekend. When I reconnected it several hours later, everything seemed to return to is proper state with one exception. The windows will not roll up with "one-touch". They still roll down with "one-touch" as they should...just not up. Is there a setting somewhere, or am I just retarded and they have never rolled up with one-touch...or what?
Thanks in advance guys!
Old Nov 15, 2004 | 02:45 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Before amdeutsch steps in with his usual, RTFM for how to re-synch the windows. That should clear it up; if not, I'm outta ideas.
Old Nov 15, 2004 | 02:52 PM
In the market
I've done the searches on the forum with no luck. Perhaps I am searching the wrong terms, or perhaps this issue hasn't yet been addressed. It has been a while since I have gone through the manual in close detail, but yes I did flip through it before posting and found nothing pertaining to this specific problem. I am sure the dealership will help, but they are a bit out of town. If somone here just happens to the know the answer, it would be extremely helpful. Thank you for you insight though.
Old Nov 15, 2004 | 03:01 PM
MB-BOB's Avatar
Admin Alumni
See Garage
From the manual, try this...
Close each window one at a time, and hold the switch beyond its auto-up detent position for 3-4 seconds after the window is closed, then release. This should reset the auto up function. This procedure can also be used to reset the auto down function... for windows, sunroofs, and power seats (if you got-em), because all these use the same memory module. If that doesn't work, you'll need to take a trip to the dealer for warranty repair. Let us know if this works.
Old Nov 15, 2004 | 04:42 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
That method works exactly to the "T" ! I recently had to reprogram all of my windows & Pano-roof for the same reason. Followed instructions as stated above, and bingo... all done ! Easy fix !
Carlos
Saprissa@aol.com
Old Nov 15, 2004 | 05:32 PM
HITMAN's Avatar
c230 kompressor
i need to do that to my pano roof, i noticed the one touch feature stoped working
Old Nov 15, 2004 | 07:16 PM
In the market
Did the trick! Thanks Bob!
Old Nov 15, 2004 | 07:48 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Originally Posted by Brunelleschi
I've done the searches on the forum with no luck. ...
RTFM = Read The ****ing Manual. Would have been no need to even search if you did that.
