Aluminum door pins
There seem to be several type of door pins available. Some with the MB logo, others claim to be Brabus... I don't mind if they are made in China; I think they will improve the interior. Any coments?
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
BTW... how difficult to install are these?
-Mike
If you do a search on eBay they have several types. There are ones that even come with the surrounding ring in the same material. I also saw ones that level with the door surface once the door is locked (a big plus).
no risk, looks sweet, im in!
will report back with pictures once i get em installed...
formymercedes.com has some nice chrome and satin aluminum pins and pin surrounds, but according to Jerry there he says aftermarket pins will only fit if the stock pins that could be screwed off. I've tried twisting the pins on my car but it won't budge a bit. Anyone else tried this?
I noticed that the surrronding rings on the w204 have a small angle to follow the door surface; the rings selling on ebay are flat... don't know if this is going to be a problem.
If you think you're making a significant change in the car, take a look around at everything else that could conceivable be replaced.
Believe me, the next thing that happens is a slipped screwdrive and gouged moulding and glass.
On the other hand, if someone came up with some really comfortable seats...I'm in.
W203 C Class Models
W124 W210 W211 E Class Models
R170 R171 SLK Class Models
W208 W209 CLK Class Models
C219 CLS Class Models
Check product descripton before buying.
Mine look so bad that you can even see the mold lines in the plastic!
