Old 06-04-2015, 06:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
w204 secrets thread...
Rating: Thread Rating: 11 votes, 4.64 average.
Old 04-15-2009, 11:54 PM
  #401
OpAmp's Avatar
2016 C300
Everyone probably knows that you can close your windows and moon-roof by holding down the lock button on your key. But I wonder why they made it so that we have to hold it down. I wish there was some feature you could enable where the windows would automatically go up/close when you lock the car. Seems much more logical.
Old 04-16-2009, 08:30 AM
  #402
sameer13's Avatar
2009 C300 4Matic
Feature above would not be usefull because it would close all windows everytime I lock the car but what if you wanted to leave the windows down a bit or the sunroof open a tad in the hot summer here to clear the hot air? I would rather have a choice than for it to do automatically.
Old 04-29-2009, 04:51 PM
  #403
BER6972's Avatar
C300
Help!
So the secret command menu that we should be carfeul in not changing. Well I don't know what I changed, I got a little carried away, and now my navi totally disappeared from my screen. Does anyone have the original settings, that I can adjust it to. Thanks! I have the C300 '08 sport with the mm package.
Old 04-29-2009, 06:08 PM
  #404
Egonvdv's Avatar
E 300 AMG-Line diesel-Hybrid - 2021
Originally Posted by Ron Jr
I would much rather have the memory seats. Takes me forever to find my spot after someone moves the seat.
You let others drive you car???
Old 04-30-2009, 10:53 AM
  #405
dragonii's Avatar
Mercedes S204 C320 CDI
My ex-BMW E46 had the feature much better implemented than Mercedes since :
- Based on RF and not on IR (what were they thinking ?)
- No need to hold down the remote. Long press and that's it. Probably one of those pesky EU-US differences...
Old 04-30-2009, 11:01 AM
  #406
vic viper's Avatar
S213
The old W202 had IR-remotes, the FBS3 lock system uses RF
Old 04-30-2009, 11:03 AM
  #407
berkut_g's Avatar
W204 C320CDI
IR is for opening and closing all windows . summer feature
RF is for the rest .
RF should have been for all including windows.
Old 04-30-2009, 11:09 AM
  #408
kaku's Avatar
2009 C300S 6mt
where is the IR sensor located at on the car? is it on/near the door handle?
Old 04-30-2009, 11:15 AM
  #409
vic viper's Avatar
S213
"(what were they thinking ?)"
Probably a good thing to be in visible range of the car when you want to roll down the windows using the key,
I dont think anyone would be laughing if the windows went down in pouring rain due to the key being pressed in your pocket.
Old 04-30-2009, 12:42 PM
  #410
BER6972's Avatar
C300
Anyone know how to put it back to the US settings, I'm stuck with the TMC mode display on my navigation,and it will not access any local POI?
Old 04-30-2009, 01:04 PM
  #411
theinmoe's Avatar
C350
Do you have a picture of TMC mode display?, If you change the Nav setting to aftermarket option, you will not see the map anymore.
Old 04-30-2009, 01:16 PM
  #412
BER6972's Avatar
C300
No it just displays it but it doesn't workit just gives an error and says TMC station not available. So frustrated
Old 04-30-2009, 01:20 PM
  #413
sameer13's Avatar
2009 C300 4Matic
It's located on the drive side door handle near the key hole.
Old 04-30-2009, 01:26 PM
  #414
aprince2die4's Avatar
08-C350 black/black
also if the button sticks on the key remote...which is the case with my ls400....i've had a few mornings where i'd walk out and all my windows were down and sunroof open...
Old 04-30-2009, 01:30 PM
  #415
Bokx_350's Avatar
C350
My audi had this feature with RF. I loved it, but I'd like to share that 2 occasions I got back to my car and all windows were opened (one of those was raining pretty bad). I'm not saying it was the system, but I never figuered how if happened. Even so, I would much rather have it RF (I never use that feature in my w204 just because I have to point at the door).
Old 04-30-2009, 07:47 PM
  #416
OpAmp's Avatar
2016 C300
I'm saying there should be an option in the instrument cluster where you can enable/disable the feature.
It would be like this:
Enable = all windows up when locking car.
Disabled = what we have now.
And yeah, the IR is pretty bad too. Makes it hard to use.
Old 05-02-2009, 03:37 PM
  #417
killacam7479's Avatar
2009 C300 Sport 4Matic, 1999 Jeep Grand Cherokee Laredo
Anyone figure out if the US 2009 w204 has the ability to move the side mirrors while reversing? I know there were posts and Canada models work, but I wasn't sure if this worked in a 2009 w204 in the US . I tried following the directions and couldn't figure it out.
Old 05-02-2009, 06:51 PM
  #418
woedee's Avatar
w205 - Black
Access engineering menu >dvd settings > remaining change and press "hang-up" + "#" + "*" simultaneously. This will reset the remaining change count & you could then switch back to US.
Originally Posted by Bokx_350
...I never use (the roll windows down w/RF feature) in my w204 just because I have to point at the door.
Yeah I dont use that feature either - -it's kinda douche bag-ish
Old 05-03-2009, 10:36 PM
  #419
Sorry to ask again, but does anyone know the answer to my question? I have memory seats in a 2009 US C300. I'm wondering if that adjusting passenger side mirror when in reverse works on US models?
Old 05-03-2009, 10:37 PM
  #420
nickm's Avatar
C350
I wish it did but sorry, it doesn't...
Old 05-03-2009, 10:39 PM
  #421
ptronus31's Avatar
2008 C300
No. I am not sure why, but it is not enabled. It may be because the selector switch for adjusting the mirror is only on for a short while after pressing it (most other cars with the feature require switching the selector switch to the passenger mirror to activate).
Old 05-03-2009, 10:42 PM
  #422
ptronus31's Avatar
2008 C300
Here is another "secret" - of course, pressing the channel select button on the steering wheel advances the radio to to the next preset, but holding it will advance it to the next channel. When using CD or iPod holding the button fast-forwards (or reverses) the current song.
Old 05-04-2009, 11:38 AM
  #423
nukefixer's Avatar
2012 US Edition C300 Luxury 4-Matic
Very good secret/tip
Wow, thats a very secret/tip, that was one I hadn't heard about, thanks a bunch I was wondering how to change the channel without opening of the radio dash cover, I never do as I listen to sat radio most of the time, and it seems you can only use the knob on console after opening the cover?
Thanks again, its much appreciated!
regards,
Nuke
Old 05-04-2009, 11:53 AM
  #424
TB5...'s Avatar
2009 C300 4Matic
not really a secret... more like a unknown audio function (by me at least)
apparently when you turn off the car and you are listening to a track...
it rewinds about* 10sec or so when you re start the car or player.
this way you will hear the part of the song you might have missed when taking the car off.
Old 05-04-2009, 01:28 PM
  #425
joshg1001's Avatar
2017 E300
wow ^^ thats german precision at its finest
You have already rated this thread Rating: Thread Rating: 11 votes, 4.64 average.
Quick Reply: w204 secrets thread...
