Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Access COMAND Secret Menu
Step by step instructions for do-it-yourself repairs
w204 secrets thread...
#155
Hi:
Just want to ask. I have the alarm system as an option in my c200k. When I activiate it, the signal lights blink. But how can I enable the "beep beep" sounds?
Thanks in advance.
P.S. My alarm is an factory option and not from the dealer.
#157
1 Post
2014 Mercedes C250 Coupe, 1998 SL 600 sport
RickP
#158
1 Post
Regards,
Rick
#160
Yep - the red gauge colour is for any 'serious' error messages. I've had it for driving off with a door slightly open.
#164
I thought we talked about this? Did you try opening your window then closing and activiating the lock alarm, then reaching in with you hand to unlock the door and open it with the alarm set? If you have one the alarm will go off and we can settle this question....
Regards,
Rick
Regards,
Rick
i dont know man , i think my local MB factory did not put alarm system ..
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
to solve second situation , they suggested me asking local MB techical guy to input Nertherland or Norway alarm system codes , then here you go ..beep beep .@@..i will call them soon ..
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#167
I found another secret i dont know if this one was already discovered... So basically you can have 2 speedometer in MPH as your normal dial one and another opition which you can enable it or disable it is a digital KM speedometer below your trip and total milage display. direction: Settings/(The first one which i don;t know right now bc im at work lol)/Digital KM. from there you should know what to do. sorry for not being detailed right now im at work i cant do go in n out to my car.
#168
P26Official (09-15-2023)
#169
You can choise between mph or kmph.... I'm in The Netherlands so my normal speedo meter is in KM/H, if i go to the UK/US i can set the digital second speedo in MPH.... Dont know if this is an option in the UK, on my previous car (A200 Turbo) i also had the choice, but i know that people in the UK didn't have a choice.
#172
i checked it out settings/cluster/(hit the down arrow) additional speedometer.
when you dont have it you display where you can see you miles and mileage below that will be blank. if you enable it you will ahve a digital speedometer.
#174
I think for the Australian version, if we select to display the additional speedometer, it will replace the display of the outside temperature.
#175
i have the us spec version, and that IS an option in the us spec version. at least in mine, found out how to do that the 2nd day i got the car, b cuz i live in germany and i needed to know before i got a speeding ticket. anyhow, go to the settings and scroll down it ask something like change display??
