Old Jun 16, 2015, 01:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
Print Wikipost
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS
Old Sep 13, 2012 | 12:58 PM
  #251
Silvrvette's Avatar
08 c350
Originally Posted by Eduardo Broring
A funny Question! Is my wife will complain about H&R SS? Do you feel much difference between Stock and SS?
Cause I just bought the SS springs and 19 rims.
I honestly don't feel much of a difference(and I am female). Ive got the HR springs and 19 vertini wheels.
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-bb.jpg
Old Sep 13, 2012 | 01:31 PM
  #252
mangoango's Avatar
08 C350
Originally Posted by rev604
Hi guys, just got my H&R sport and 19 Gnosis installed, the ride quality after lowered is surprisingly as comfort as factory. Here is the pic for your reference, the front is sitting at 1.5 finger and 1.75 in the rear but I believe it will bit just a lil bit lower after the spring settles in.
Very nice! Gnosis HS201 right? What are the wheel & tire sizes?
Old Sep 13, 2012 | 02:56 PM
  #253
edubenz's Avatar
Mercedes w204
Attachment 243450
You have the HR Super Sport?
Old Sep 13, 2012 | 02:59 PM
  #254
Silvrvette's Avatar
08 c350
Yes I have HR ss springs
Old Sep 13, 2012 | 03:02 PM
  #255
edubenz's Avatar
Mercedes w204
I love the black Rims.. Looks amazing!! I'm going with black rims too. I will show the results soon!!
ANy issue with rubbing? Do you know your offset?
Old Sep 13, 2012 | 03:08 PM
  #256
Silvrvette's Avatar
08 c350
Thanks!! 45f and 48r ... only rubbing I have is over excessive dips in the road.
Old Sep 13, 2012 | 03:15 PM
  #257
Showa's Avatar
99' Lexus RX300-retired, 01' BMW 330i
What's up guys! My question might had been covered before but I'm still confused. My coupe has advanced agility pkg. Will H&R sport spring or Eibach Pro spring work w/o any modification?
What can I do to drop(mild) the coupe that equipped with the advanced agility pkg? Thks
Old Sep 13, 2012 | 03:27 PM
  #258
edubenz's Avatar
Mercedes w204
Thanks!!
I always put 4 people in the car so thats why I'm little scare about
Old Sep 13, 2012 | 03:50 PM
  #259
Silvrvette's Avatar
08 c350
Thanks!!
I normally don't carry many people. Usually its just two with two pitbulls.. but I have had 5 50+ lbs of dog food at one time and I did rubb on bumpy roads/interstate.. but not on side/feeder/neighborhood roads.
Old Sep 13, 2012 | 03:55 PM
  #260
DEE-AMG's Avatar
C300 BLACK
Does Eibach make Sportsline springs for the w204? are H&R better as most on this thread seems to be running them.
I ran Eibach Sportsline springs on my BMW 3 series and they were great for handling, car glued to the floor and comfort was surprisingly excellent, I was running 19s also. Car was slammed.
Old Sep 13, 2012 | 04:12 PM
  #261
mangoango's Avatar
08 C350
That's weird. Those offsets typically work on the w204, assuming you're running 19x8.5 in front and 19x9.5 in the rear. What brand and size are your tires?
Old Sep 13, 2012 | 04:23 PM
  #262
DEE-AMG's Avatar
C300 BLACK
there are loads of other well known companies that makes springs/suspensions.
Just to name a few;
Apex, PI, Spax.
has no one thought about trying them out? they seem cheaper.
Old Sep 13, 2012 | 04:31 PM
  #263
Silvrvette's Avatar
08 c350
They work.. just rubs sometimes(not on a daily basis just over large/huge dips in the road).. tires are the new nitto motivo's not sure the size off the top of my head and it's pouring rain outside.
Old Sep 13, 2012 | 04:43 PM
  #264
kevink2's Avatar
2004 Mazda6, 1993 RX7
Just to be sure, you have a switch on the dash for sport and comfort? That switch in sport makes the viscosity of the shock oil much thicker, making the ride very firm with little roll. It aso includes the basic sport and comfort adjustments of the transmission shift points.
Old Sep 13, 2012 | 05:14 PM
  #265
kevink2's Avatar
AFAIK, Eibach only sells Pro-Kit's for the w204, which are close to the H&R sports in performance and drop. H&R also sells super sports for the big drop. these would be similar to eibach's sportlines, if they were available.
The H&R super sports are dual rate springs. They have a slightly stiffer rate for normal cruising, but are quick to change to a much stiffer rate with more load or deflection. They run into problems when the as-manufactured spring is off spec and when cruising, you are resting on the springs in stiff mode, providing a rough ride.
Old Sep 14, 2012 | 03:42 AM
  #266
rev604's Avatar
2009 C300 Sport AMG
hi mangoango, yes it's HS201 and i am using 235/35/19 255/30/19
Old Sep 29, 2012 | 08:54 PM
  #267
kevin.vernal's Avatar
2012 C63 ///AMG coupe
should I go H & R sport or supersport???
Old Sep 29, 2012 | 09:06 PM
  #268
edubenz's Avatar
Mercedes w204
If 19 rims SS for sure!!
Old Oct 7, 2012 | 02:28 PM
  #269
anyone know the part # for the 5mm spring pads? thanks
Old Oct 7, 2012 | 02:31 PM
  #270
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
~ I have a set on my lowered c coupe and saved the packaging. I will follow up with the part later today.
Old Oct 7, 2012 | 02:34 PM
  #271
tnx man... but u got the pads @ the dealership right?
Old Oct 7, 2012 | 03:15 PM
  #272
~ yes. the cost is less than $25.
Old Oct 8, 2012 | 09:25 AM
  #273
5mm rear spring pad part #: 8017374737-10
Old Oct 8, 2012 | 12:31 PM
  #274
just went to the dealership... part # not showing up in their system
Old Oct 8, 2012 | 01:25 PM
  #275
Doanster's Avatar
C300 Sport 6MT
Part numbers for the sedans (well, my '09 anyway) below. Not sure if the coupes or face-lifted models are different or not.
A 210 325 01 84 - 5mm Spring Pad
A 210 325 02 84 - 9mm Spring Pad
A 210 325 03 84 - 13mm Spring Pad
A 210 325 04 84 - 17mm Spring pad
