Back up camera
Rating: Thread Rating: 2 votes, 4.00 average.
Old 05-12-2010, 02:17 PM
  #76
deusexisagod's Avatar
w204 c220 cdi
I have a problem...i installed the camera and set the option to SRVC and waited 10 minutes with the doors closed ...but when i put in reverse nothing happens....i have istalled a vim module...doaes that affect this ?!?
Old 05-13-2010, 05:46 AM
  #77
PREMIUM SPONSOR
rob13572468's Avatar
ML350, Lotus Elise
Originally Posted by Nuru
Did anyone ever verify that withou Xentry/DAS, we can get to the following menu?
[Prohibition setting]
Navi speller: Enable(0)
Navi map: Enable(0)
Address book: Dis > 5km/h(3)
TV/Video: Dis > 5km/h(3)
Navi (car position): Enable(0)
Navi (destination): Enable(0)
Navi (city): Enable(0)
Navi (name): Enable(0)
Navi (phone number): Enable(0)
Navi Scroll Map: Enable(0)
Other Distraction: Disable(255)
and how - I figured it was available via DAS,, but via the engineering menu????
cant do it either way.. The only settings that the radio will accept are 1. Video in park 2. Video in drive and not moving or 3. video in drive up to 5km/h
Old 05-13-2010, 05:47 AM
  #78
PREMIUM SPONSOR
ML350, Lotus Elise
Go to service menu and then settings.. make sure that rear view cam is enabled there as well...
Old 05-17-2010, 01:18 PM
  #79
anwar_m14's Avatar
2003 E320 Pewter KG
this is real work
Old 05-21-2010, 03:26 AM
  #80
MURTAZAC350's Avatar
2014 E 550 Cabriolet. Black exterior with red interior, 2009 C 350. 2013 Toyota highlander.
Hello
is there any place where i can get the backup camera installed. I am not a DIY guy and wont be able to do it myself. And any ideas as to how much it will cost ?
I have a 2009 C350
Old 05-21-2010, 03:35 AM
  #81
Jae Duk's Avatar
'09 C63
I got mine done for about 3-400 I think. That was labor cost. I thought it was pricy but supposedly the guy comes highly recommended. BTW where are you located?
Old 05-21-2010, 03:38 AM
  #82
Philly but moving on to chicago soon, the quote i got was $1300 . Who is this guy of yours and where.
Thanks for your post
Old 05-21-2010, 05:35 AM
  #83
Jae Duk's Avatar
'09 C63
Torrance, CA. It's part of LA. That price is just for labor, so if you include the price for the parts from Midcity it came out roughly to I think 11-1200? Try asking midcity engineering. I think they're located in Chicago, and maybe they'll do the install for you and give you some discount if you buy their part.
Old 05-21-2010, 07:51 AM
  #84
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Any car stereo installer can do this in about an hour it is very easy if you follow the DIY directions that have been posted here. Don't forget to watch the You-Tube video on how to remove the stereo. The hardest part is running the video cable from the trunk to the dash.
Old 05-21-2010, 12:01 PM
  #85
joshg1001's Avatar
2017 E300
any "highly recommended" installers in the bay area?
Old 05-21-2010, 03:48 PM
  #86
kavehh's Avatar
C220 09
I dont have backup option on mine so is that mean i cant just buy the camera and wires to install the camera?
Do i need something else as well?
Thank you
My car is UK version
Old 05-21-2010, 10:20 PM
  #87
Ron Jr's Avatar
Thank you
You need the Mutli-Media system.
Old 05-22-2010, 09:08 AM
  #88
Kaiba's Avatar
AMG
Just found out cool stuff this day :
While in motion , press Up and Down arrows on the steering wheel in same time. Keep pushing for 5 secs , and look at the screen. You should be able to activate the camera while driving and watch behind you !!
Funny ... Sorry if its a repost.
And by the way , if MidCity comes here , before installing the module , the BT was constently on , pairing with my phone automaticly. Now , with the module , there's a message asking if I want to activate BT. Can't we overpass this message because I have to press Yes each time .... Annoying....
Old 03-06-2011, 12:13 PM
  #89
kman2k's Avatar
W212
It happen because the way set the jumper on the VIM box was wrong (the way you set it was VIM always in active) . Make sure you set all 3 numbers OFF. Use the Hang Up call button to activate the VIM when needed.
File Type: pdf
Old 09-22-2011, 10:12 AM
  #90
karate70's Avatar
C200k
Help... I have gone through the whole forum with regards to backup camera but I can't seem to get it to function. I have a 2008 c200 compressor with the mm package. I went through all the steps posted on this forum... Ie press hang, 1 and # to go into the engineering mode then into hu parameter, change rearview camera to installed, went into system and activate reverse gear, took out the car key waited for 5 mins yet i could not get the check background screen on. I have tried everything I gathered from various posting in this forum and nothing seems to work.
Any help, suggestions are much appreciated.
Thx
Old 09-22-2011, 11:44 AM
  #91
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera. 2002 QX4
Originally Posted by karate70
...press hang, 1 and # to go into the engineering mode then into hu parameter, change rearview camera to installed, went into system and activate reverse gear, took out the car key waited for 5 mins yet i could not get the check background screen on...
Did you disable the AUX Video? I was told you can't have both camera and AUX Video enabled.
However, mine is 2011 C300.
Old 09-22-2011, 08:04 PM
  #92
karate70's Avatar
C200k
Thx c300ca for your response but yes I have followed everything. I disabled the aux video yet without success... Hope someone here could help. I have already done up all the necessary needed for a backup camera... Mounted n pulled all the wiring already, just can't seem to get the check surrounding frame... I m so used to having a reverse camera.
Old 09-22-2011, 08:54 PM
  #93
C300CA's Avatar
... I have followed everything...
Did you close all doors when you set up? That is one of the steps I followed.
Old 09-22-2011, 09:26 PM
  #94
karate70's Avatar
C200k
Yup I closed all doors during set up... Did everything, removed key, close doors and waited for 5 mins but alas still without success... Do I need to upgrade the software or I still miss out somrthing??????
Old 09-24-2011, 10:16 AM
  #95
karate70's Avatar
C200k
Bump... Please help... Thx
Old 09-25-2011, 12:33 PM
  #96
mbgt's Avatar
mercedes c350
I have the same problem I`m going to try a software update at my dealer
Old 09-25-2011, 08:05 PM
  #97
karate70's Avatar
C200k
Thx mbgt... Hope you keep me posted on the progress after the software update...
Old 10-02-2011, 10:07 PM
  #98
karate70's Avatar
C200k
Hi mbgt, any success after the software upgrade? I am also having problem with vim. After installation the vim, initially it works but an hour later it will stop working as soon as I reach 20kmh. Before it was 5kmh. Still can't get both backup camera n vim to function. Any suggestions will much be appreciated
Old 10-19-2011, 10:01 PM
  #99
karate70's Avatar
C200k
Just like to share my experience. I managed to get everything to work finally. I took it to the dealers place to upgrade my software. Initially the upgrading had a problem as halfway through the process everything stalled. I had to remove the Vim in order the upgrade of software to b successful. After the upgrade and following the other treads in here I managed to get both the vim n backup camera to work. I am a happy man here. Just thought I share.
Old 10-20-2011, 02:52 AM
  #100
C300CA's Avatar
Great to hear yours is finally working.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.00 average.
Quick Reply: Back up camera
