C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics
Old Mar 29, 2012 | 09:09 AM
  #101
papashango's Avatar
This and that.
Originally Posted by tasho3
lol NO! nothing can void your warranty unless the dealer proves that the mod you did caused a problem. this is simply cosmetic, not mechanical or electrical.
How can I find out for sure? Contact the dealer?
How about other things say such as if i change the license plate lights to LED's. Could that void it? How about the side marker lights in the front? I wanna get rid of that yellow marker and install a white one.
Old Jun 19, 2012 | 02:10 PM
  #102
JasonHu's Avatar
2012 C300 4MATIC, 2014 Tesla Model S P85
Looking to do this on my 2012. Thanks for the part #s!
Old Jun 21, 2012 | 11:07 AM
  #103
twitspassion350's Avatar
w204 C350 sport
Be careful your rear diffuser has a different part number due to its remodeling.
Old Jun 21, 2012 | 01:35 PM
  #104
MoneyMike23's Avatar
'08 C350
DAMN GOOD POST!!!!!
Old Nov 7, 2012 | 01:20 PM
  #105
Nunu's Avatar
C250
Where did you get the C63 Brackets?
Old Nov 7, 2012 | 04:03 PM
  #106
w204 C350 sport
Local Mercedes dealer.
Old Nov 8, 2012 | 01:38 AM
  #107
SheryarYO's Avatar
C63
i actually have some brand new brackets i bought for my c63 that i had bought to use with my new diffuser, but it turns out i didn't need them after all. the total came out to $77.79 shipped from parts.com which is OEM products. i was going to ship them back, but wouldn't mind helping out a fellow forum member. if you're interested in $55, then PM me (because I probably won't check this thread again) and I can send you pictures and whatnot. they're still wrapped in the original protective sleeves with the Mercedes parts number sticker on them.
Old Jul 28, 2013 | 06:20 PM
  #108
jgoga's Avatar
2013 C300
Originally Posted by VaderSS
syrAMG, KuiDaCroat22, aowhaus, PolePosition & Stryder04 ..... Thanks!
The Diffuser is a 'No-Fuss Bolt-In' process with no alignment issues.
Here was the price breakdown;
Tips were $84 each x2= $168 .........(204 490 63 27 & 204 490 64 27)
Brackets $24....each x2= $48 .........(A204 885 23 14 & A204 885 24 14)
Diffuser ......................$264 .........(A204 885 45 25)
Rivets......................... Free! ........(had some lying around)
Exhaust custom welding $275
........Grand total: $755
Using all factory parts..... Priceless!
I found diffuser PN: 204 885 39 38 and you have a different part number, do you know what the difference is?
Thank you,
John
Old Dec 28, 2013 | 06:19 AM
  #109
Jpslikk's Avatar
C300
Those are stock c63 diffuser?
Old Feb 25, 2014 | 01:54 AM
  #110
aznmode's Avatar
2010 c300
Planning to do this. Is there any reason I shouldn't just weld the extra tips and not have it functional?
Old Feb 25, 2014 | 02:12 AM
  #111
W204white2010's Avatar
W204
You can just weld it and not have the extra tips functional, but most members on the board just buy the quad tips off ebay or have their local shops fabricate a Y pipe like how VaderSS did it
Old Feb 25, 2014 | 02:58 AM
  #112
aznmode's Avatar
2010 c300
Thanks I think ill weld it then. I was mainly concerned with losing power so I figured I shouldn't mess with stock. Car is already slow as it is.
Old Feb 25, 2014 | 04:58 AM
  #113
aznmode's Avatar
2010 c300
Sorry Vader. Chopped you image. What do you guys think of these tips? It's for S class. [/URL]
Old Feb 25, 2014 | 05:05 PM
  #114
Naverino's Avatar
2013 C63 w/PP, 2014 ML63 AMG w/PP
Hey guys I just got a 2012 c350 and have a question. Do I need c63 brackets as well? I got a new diffuser and it didn't come with brackets. If I do, will the part numbers already listed work for my model year? If not can anyone help me with the correct part numbers for the 2012 model year?
Old Feb 26, 2014 | 12:48 AM
  #115
minazih's Avatar
C 350 4matic 2012
Question
I would like to know do we need to buy Brackets to install the diffuser.
I just bought Carbon Fiber diffuser to install it on my C 350 2012.
Thanks,
Old Feb 26, 2014 | 07:19 PM
  #116
aznmode's Avatar
2010 c300
Called my dealer in Fremont CA about the brackets for a 2010 diffuser and each is $67. What rip off.
Old Feb 26, 2014 | 07:39 PM
  #117
aznmode's Avatar
2010 c300
Thanks,
Short answer...recommended
https://mbworld.org/forums/c-class-w...w204-pics.html
What I wonder is if the existing one can be reused. I assume no since every DIY I see always mentions buying the bracket. Mines a 2010 so brackets might be different from 2012.
Old Feb 26, 2014 | 08:09 PM
  #118
aznmode's Avatar
2010 c300
Ended up buying my brackets for my 2010 from here. $31.60 each. Looks like they're from Monterey, CA so I should get them by next week. But it sucks that I can only ship to the billing address.
http://www.benzpartswholesale.com/
Old Mar 8, 2014 | 08:13 PM
  #119
aznmode's Avatar
2010 c300
Just a slight update on mine. For anyone still wondering on pre facelift, the brackets are recommended and you cannot reuse the old one since it is stuck on there's and no way for you to reattach it to the c63 diffuser. If you don't install the brackets the diffuser is wobbly. But here is how I installed the brackets into the diffuser that costs me about $6. I didn't have a riveting tool and I think this just works just as well. See below image for parts and sizes. I went with M5 metric since it was just slightly bigger size as the hole but just big enough so it can still thread through making it more secure IMO. You cant screw it in (thats what she said) by hand so you will need a socket wrench.
4 bolts, 8 washers, 2 wing nut, 2 nuts. Bought at Home Depot.
Here I threaded the bolt all the way through first with washer in place, but stopped as soon as it felt tight. I didn't want to keep tightening it so it wouldn't strip the hole.
On this side I put a washer also and used a socket wrench to screw in the nut while using another socket wrench to keep the other side still to prevent it from spinning and stripping the hole when I tighten this side.
I used wing nut here since there was no way I can get a socket wrench in. But here I first screwed in the bolt just enough so the wing nut can meet with the bolt and held the wing nut in place with a long nose pliers as I tightened the bolt all the way. Washers on both sides as well.
End result. Since the bolt is threaded into the bracket and also secured with nuts and wingnuts this should make it secure and will not allow the bolt to loosen over time. Hopefully anyways.
The removal and installation of the diffusers was fairly easy and there's already a thread on that so I didn't bother taking pictures as I did it exactly the same. But I did find that working your way from one side and go clip by clip was the best way and not just pull the whole diffuser out. Same goes for putting the diffuser back in. And I did I have to put my hand behind the bumper next to each clip so I can push the clips in place better...one at a time.
Now I just need to get my tips done but in the mean time I have to drive it this way.
Old Mar 28, 2014 | 10:05 AM
  #120
minazih's Avatar
C 350 4matic 2012
Installed the Carbon Fiber Diffuser
Hello,
Yesterday I installed the Carbon Fiber Diffuser on my C 350 2012.
Actually for the carbon fiber one you don't need to buy Brackets.
You can use the original Brackets.
Removed the Old Diffuser:
Installing Original Brackets:
After Installing:
Thanks,
Minazih
Old Mar 28, 2014 | 12:04 PM
  #121
TheRulesLawyer's Avatar
C350
Hello,
Thanks,
Minazih
Which one did you get? Since its CF, I assume its a ebay one instead of MB OEM.
Old Mar 29, 2014 | 01:38 AM
  #122
minazih's Avatar
C 350 4matic 2012
That is correct, I got it from Ebay.
Old Mar 29, 2014 | 01:40 AM
  #123
C350
Any chance you can link it? There are a ton of options. If yours fits well, it would be nice to know the seller.
Old Mar 31, 2014 | 10:27 AM
  #124
minazih's Avatar
C 350 4matic 2012
The seller removed the Add but per example you can contact the seller for the bellow item to make sure that fit your car but I am pretty sure it is same as mine.
http://www.ebay.ca/itm/C63AMG-Style-...vxp=mtr&_uhb=1
Thanks,
Minazih
Old Apr 18, 2014 | 12:46 PM
  #125
C350
Just finished this up on my 2012 c350.
The AMG brackets and the originals *have* to be the same. Don't waste money on them if you have a facelift model. Its a pita to get the diffuser started coming off, easiest to pry from the inside near one of the exhaust pipes I found. The ebay h style tips are a little on the long side, but they can be but no problem. If you want them to stick out like an inch, no problem. Welding them in was about $100. You can get the same tips on aliexpress for just over $200 instead of the $285 or so on ebay. I'm using the OEM C63 diffuser.
Rear shot.
C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics-wwlkzgo.jpg
Tips. You can have them mounted in further if you like.
C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics-m1d3ogp.jpg
