DIY: Rear-View Camera under $200
just get this.
L
Believe it or not, just pull on it or use a wedge to pop it out with some strength. It'll pop out. The sills are teh easiest part.
Kenwood CMOS-200 Power Wiring Question:
1) You know how you have 2 power sources Needles. A) Reverse Light B) Accessory Power.
After i run everything to the back, where do i run the Accessory Power to? Instruction says to run the power to the Engine Key, but it seems that most people are running the power from somewhere else? Where do i run the power to because it has to be a NON CONSTANT Power Source.
Any help or info would be much appreciated.
Thanks..
Thanks..
Thanks..
Just run it to the reverse brake lamp. Power only goes to it when you engage reverse.
Thanks..
post pictyres of the camera installation i m ready to install kenwood cmos 200!
