W204 7G-TRONIC Gearbox
Looking for links/info & detailed instructions on how to check, drain & refill the 7G-TRONIC gearbox with correct oil.
Also for the C350 V6 engine.
You don’t have to remove the plunger, but can be very messy, as you have to remove the pan full of fluid.
Replace filter & gasket.
Then it gets filled from the drain plug under pressure.
To check/correct the level it’s almost impossible to do unless done at MB.
You ad a little more than what is necessary, than at a cretin temperature (checked with DAS) remove the filling device & watch the excess fluid come out & cap it before it starts to sputter.
I hope you do it when required, and make sure your dealers understand what they are doing.
With the 722.9 they figure that would be a good idea to remove all the crap from the break in period & put fresh fluid.
I gess.
The only thing I find excessive in the maintenance schedule I read for my 2009, is brake fluid every 20K miles. That really is excessive in my opinion.
