c350 4matic 0-60mph
Old Dec 15, 2008 | 04:53 AM
kit0515's Avatar
C350 4Matic
c350 4matic 0-60mph
I recently tested my c350 4matic's 0-60mph and the results were avg of 7.4s. that's 1.1 seconds slower then the advertised speed. Me and my friend was in the car. I also used the iPhone's dynolicious app to test my peak HP, and has an avg of 161hp. so i am wonder if it is my engines that screwed or something else.
will being in dyno mode help??
if it really is the engine i am gonna warranty it, hoppfully getting an engine swap due to underperforming engine. please shed me some light.
thanks
Old Dec 15, 2008 | 06:06 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
thanks
How did you time it? Was it accurate?
Old Dec 15, 2008 | 09:04 AM
kit0515's Avatar
C350 4Matic
i used the iphone accelerometer to determine that. it's supposedly very accurate. btw the 161hp is whp. also, i did over 50 runs, or half tank of flooring the engine. so it should be rather accurate.
Old Dec 15, 2008 | 09:17 AM
Blk04cobra1's Avatar
2002 S430, 2004 Cobra, 2004 Tahoe
For some reason I just cannot see that being very accurate. Maybe consistent, but it would be shocking if your C350 were truly 1 second off the advertised 0-60. Also, I would think you'd be closer to the 190-200 whp range, not 161whp. Just for clarification, I would try to find an AWD dyno in your area if you're concerned about something being wrong.
Old Dec 15, 2008 | 11:31 AM
_MBMW_'s Avatar
2010 E90 335i, have W204 C350 and W211 E350 in the family
IPhone's software is not very accurate. It was tested on another boards and proved to be inaccurate. If you want to really measure you 0-60, you will be better off with GMETER, or better yet take it to the track.
Old Dec 15, 2008 | 12:58 PM
kit0515's Avatar
C350 4Matic
thanks for the replies, and maybe you guys are right bout the times, but the max amount of G's the car pulled was usually less then 0.9, usually in the low .8 range.
cause there's people who said the iphone is accurate and some not. guess i will need to really dyno the car.
Old Dec 15, 2008 | 04:56 PM
Oh man the iphone is not accurate at all with the 0-60 times and the quarter mile times. Our GPS in the iphones don't measure small enough movements to be accurate. That's like the worst way to measure your time! haha Take a stop watch, thats your best bet. (btw i have the iphone and am loving it)
Old Dec 16, 2008 | 12:29 PM
Filipp's Avatar
Future C300/350 Owner
I don't have a C class yet but I have used the Iphone app and achieved the advertised 5.5 seconds that is claimed for my car. So I think it is fairly accurate if you enter everything correctly such as your cars weight and etc.
Old Dec 16, 2008 | 03:09 PM
Diesel Benz's Avatar
I have not tried this, and if it measures from GPS, why do you need to enter some car specific data?
Any GPS on a cell phone only updates the location infrequently relative to the need for this measurement. The Doppler based speed measurement is more accurate here than monitoring the location of the car, the application may well use this info but the sampling rate is still far too low. I'd agree with the post micropower.
Old Dec 16, 2008 | 03:22 PM
e1000's Avatar
a quarter mile at a time
iPhone uses it's internal acccelerometer, not GPS.
Couple things to consider. If you had passengers in the car, you should be adding up the total vehicle weight I believe. I've never used the iPhone app so I'm not sure if it asks you to do so.
Also, any 4-matic car will have a larger drivetrain loss than a rear wheel drive or front wheel drive car.
Old Dec 16, 2008 | 04:45 PM
StickyZ's Avatar
W204
dynolicious is VERY accurate...more so than many of the standard, in car "docked", devices out for a lot more money. there have been several tests and comparisons on shows/in mags. obviously nothing will be more accurate than a real dyno but for 13 bucks and the convenience factor its not bad. you just have to make sure its calibrated correctly.
i don't have a ton of time to look for reviews but here's one...take it or leave it, especially from who its coming from.
http://www.youtube.com/watch?v=0-DFbJQbeSY
Old Dec 17, 2008 | 04:26 AM
kit0515's Avatar
C350 4Matic
hmm, i did another run yesterday, this time with a stop watch, and have a 6.7s going uphill. this is really confusing me. i also agree with the drivetrain loss, but will it really result in 40% loss?? but, with or without drivetrain loss, it should still approach fairly closely to advertised 0-100km speed.
and how much diff will there be with 170KG of weight?
Old Dec 17, 2008 | 10:09 AM
e1000's Avatar
170KG = 374lbs That's a LOT of weight
It sounds like you have the iPhone dyno application configured incorrectly
Old Dec 17, 2008 | 01:18 PM
Filipp's Avatar
I think uphill is also your problem and the weight is a factor.
Old Dec 17, 2008 | 02:26 PM
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
According the M-B C Class brochure, the weight difference RWD to 4Matic is 80 kg or 176 lbs.
Old Dec 18, 2008 | 02:57 PM
killacam7479's Avatar
2009 C300 Sport 4Matic, 1999 Jeep Grand Cherokee Laredo
How do you have a C350 4Matic?? I bought a C300 4Matic because I thought they didn't make the 350 4Matic...
Old Dec 18, 2008 | 03:00 PM
e1000's Avatar
canada
Old Dec 23, 2008 | 11:32 PM
kit0515's Avatar
C350 4Matic
i will try again after the snow storm. really hope its not an underpowered engine.
