comfort vs sport shift setting
Old Jan 8, 2009 | 01:34 PM
kevinhkim's Avatar
03clk320 06RRS
does it affect mpg? im getting around 17 for my 2009 c300
Old Jan 8, 2009 | 01:52 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
The sport mode in general will keep your RPMs higher as well as lock you out of top gear so I would expect it would take a toll on mileage.
Old Jan 8, 2009 | 03:59 PM
tpick23's Avatar
E63
So in sport mode the tranny never goes to 7th gear? That doesn't seem right. Try changing modes at 70mph, the rpms stay the same meaning no change in gear.
Old Jan 8, 2009 | 04:03 PM
joshg1001's Avatar
2017 E300
Comfort starts the car in second gear so that it doesnt have as much oomf. i would suspect that you would get better mileage in comfort. 17 sounds normal if you drive mostly in the city
Old Jan 8, 2009 | 04:14 PM
ni2mi2's Avatar
C300 Sport
The one thing we noticed was that in C mode the gearshift was more subtle while in S mode, there is a noticeable jerk when the upshift happens.
Old Jan 8, 2009 | 04:42 PM
newtonlaw's Avatar
2008 C300
i am 100% sure i am getting better mileage when i put it in S mode. In S mode i so get around 50km more per tank, i am positive.
Old Jan 8, 2009 | 09:13 PM
erikguti's Avatar
W204
me too... i start using Sport last month.
Old Jan 8, 2009 | 09:26 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
17mpg?? I average about 23 in my C350 and I drive hard every once in a while too.
I did a little test a few months ago and according to the car, I averaged about 27mpg at 80mph on the freeway (no stopping, cruise on).
Old Jan 8, 2009 | 10:59 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Wrong-O
It isn't right.
It's 1st gear that isn't used in addition to lowering shift points and using a higher geared reverse.
Old Jan 9, 2009 | 08:24 AM
C300Sport's Avatar
Sorry about that guys...coming from someone that doesn't get on the hwy much... It will hold you out of top gear much longer than C mode but will shift up once the speed becomes high enough.
Old Jan 10, 2009 | 01:18 AM
Robbio204's Avatar
C350
I think the C mode shifts from D1 to D2 quicker.
Old Jan 11, 2009 | 09:21 PM
comanche's Avatar
It shifts quicker on Sport mode but shifts longer on Comfort mode...is this correct?
I am confused...I kind of like Comfort mode as it doesn't shift too quickly...but shouldn't it be for Sport mode? Could mine be mistakenly set up?
Old Jan 12, 2009 | 02:46 PM
Sanjuro Makabe's Avatar
C300 4matic
Actually I think its the other way around, in C mode, it shifts "sooner", lower RPM
in S mode, it shifts "later", higher RPM...
I hope I'm right...lol o/w there is something wrong with MY car...hah
Old Jan 12, 2009 | 05:00 PM
Star & Laurel's Avatar
C 350 Obsidian Black
"C" mode the shifts will feel softer, and earlier in the RPM range. This setting will start in 2nd from a dead stop.
"S" Mode the shifts will feel harder, and be later in the RPM Range. This setting will start in 1st gear from a dead stop.
This of course is for equivalent throttle application. If you mash the throttle in either setting the engine will rev all the way to red line and shift.
Old Jan 12, 2009 | 07:29 PM
ayilar's Avatar
With 3k miles so far, my average has been 15mpg. Yes, 15 -- 90% of the time in stop-and-go downtown driving.
I get close to 27mpg on the highway, driving smoothly.
Similar here. Driving my C350 on small roads hard, rather than gently, yields a 10% improvement in mileage.
Old Jan 13, 2009 | 03:14 AM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
Milage
After 8K milage my average was 10.6L/100Km, 80% C mode, every now and then a redline burst in S-Mode. I think I am happy enough.
C- Mode it shifts smoother and earlier at lower refs.
S-Mode it shifts later at higher refs and feels quicker from pull-off, and slow down quicker till stop.
With Speed limiter activated, it cuts the engine trying to reach reduced speed quickly without brakes, I like this, C - or S-Mode.
I found that I mostly only use the paddle on steering wheel to make sure it's in 7th gear running, varies according to area.
Old May 7, 2009 | 08:35 AM
VFORCE09's Avatar
2023 C63s Coupe, 2020 CLA 45,2018 C63 Coupe,2016 C43,2014 CLA45,2013 C350 Coupe,
My C350 does the same thing
In S mode from a dead stop it shifts in to second fast than if I have it on C mode and on both times I pushed the thorttle about 1/3....
