How to remove the grille from the car?
Could I ask you guys that how to take the grille from a C300?
I recently bought a Black Mesh Grille, and going to install it by myself tomorrow, but not quite sure how to remove the grille.
Hope somebody could tell me or even show me the picture will be better, thanks.
But in all seriousness... open up the hood, remove the headlight covers.. remove the cross mounting thing to the grill. Then gently push bottom of the grill down and out. Then the grill should basically just pop out
Hope that helps...
talking of grilles....this is pretty nice and like half the original price. Is this legit?
I saw the step by step instructions
https://mbworld.org/forums/c-class-w...ing-grill.html
-turn 90 degrees on the center plastic piece thats right behind the grill (
-pull out little plastic tab (Use flathead screw driver), slide in between the small circle piece and the bigger bottom circle and twist, you can easily remove these. They are holding the intake chamber to the big plastic piece (
what the heck is this? I only have similar ones holding the plastic piece on top of the headlights but not the piece covering the raditor. Anyone have pieces of these plastic tabs? )-when taking the big plastic cover behind the grill, take a look at plastic piece, and its held by L shaped plastic pieces which are holding onto the radiator structure. It's self explanatory, I suck at explaning.
(Can someone else explain with pictures because it looks like the L shape is underneath the plastic piece that I need to remove from the step above)
Thanks for any help... If anyone have a more in-depth step by step, please send me info
*pull out little plastic tab (Use flathead screw driver), slide in between the small circle piece and the bigger bottom circle and twist, you can easily remove these. *
after removing plastic tab in centre, couldn't find small circle/bottom circle twist and slide to remove top cover! Appreciate if you could elaborate, thks in advance.
Once you do, then you can start taking the wire and tube off of the cover panel, then from there, you need to pop that entire panel off. It's connected in four places.
