SLOW GEAR Change from Foward to Backing up.
when I go in to praking garage and pull up and stop and put on R and press the gas, the car just roar little bit second and gear will grap very roughly and backs up.
Ok it might be way I drive, but it's so slow changing to R and drive reverse.
Basically when I try to parallel park, pull up to next car, and stop(Almost completely), and put on R and press gas, then it won't back up till car is standing still and my car will jerk while gets into R and move reverse.
I drove lots of sport car and they goes in to R and able to go back right away, but C is slow response to changing to R.
Is it just me? or your cars too?
Agree that its reverse gear is much less responsive than other cars that I have driven...think it is intentional
Recently I had a 2009 sport as a loaner and I really noticed the accerlation lag when going in reverse and I can't believe how noticable it is.
With the 7G, while you should make sure you have the latest software flashed, you also need to drive properly & the two of you will get on much better. They like to be driven deliberately. Bad drivers who play yo yo with the throttle will never come to terms with them. Constant throttle variation will mess heavily with the learning on the box & have it hunting between gears all the time. If you want to apply 50% throttle then do that & hold the pedal constant & the box will perform as designed. On/off throttle actions are no good - you would be surprised how may drivers don't even realise they are doing it. It is also a big fuel waster.
getting back on topic though, the reverse delay is very real and very annoying at time. in a casual parking lot it's not really an issue at all, but when you're parallel parking on a crowded narrow street with cars backed up behind you, that extra couple seconds seems like a very long and unnecessary lag. not to mention embarrassing when the car jerks back as it catches the gear.
it may or may not be intentional as many speculate, but its hard to believe that it's serving a really protective function. even after the lag, the gear catches rather abruptly. of course, waiting for the driveshaft to stop before engaging the gear is essential, but is it really doing that? then why is there no lag when you shift from rev to D?
The 7G is a proven & reliable unit in ROW where no filled for life claims were made. It needs an oil change at between 40 & 60,000 mile intervals depending on conditions.
I have this exact same problem, except the other way around, and it only occurs at an incline.
If I reverse DOWN an incline, stop, and then put the transmission into D, it doesn't get going immediately. There is a 2 second lag, followed by a noticeable tud, and then I can start moving.
I notice all the time when i back into my garage at night (I can see in the rear view mirror that after i release the brake pedal, mi brake lights will stay on for a couple of seconds.
Absolutely does not work on a downslope although some have imagined that it does on previous threads at least a year ago.
