DIY on W204 Eyelid and Foglight bulb changes?
Old Apr 22, 2009 | 10:40 AM
kevinwithdabenz's Avatar
08 c350
Thumbs up DIY on W204 Eyelid and Foglight bulb changes?
Just curious on how to get the headlights out and then the foglights to install HID or LED bulbs
Please advise if u guys dont mind
Thanks ;D
Old Apr 22, 2009 | 01:15 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Search is your friend
Old Apr 22, 2009 | 01:30 PM
who8888's Avatar
15 E350 4Matic
I know I was a once but you guys really need to use the search function and stop asking the same questions over and over again! Please don't ask how to change the interior light, the license plate light, or the side corner marker. Just search already Ask a question if you get stuck.
Old Apr 22, 2009 | 09:27 PM
08 c350
yeahh but see who8888 i didnt ask how to change the interior lights i already did a search on that one and did find it, reason for posting a how to on changing the eyelids, and fog lights is because i dont know, and couldnt find it while searching so yea...
Old Apr 22, 2009 | 09:54 PM
kaku's Avatar
2009 C300S 6mt
https://mbworld.org/forums/c-class-w...lid-lamps.html
https://mbworld.org/forums/c-class-w...-foglight.html
someone should create a detailed "official" guide that the mods can sticky for all these common questions.
Old Apr 22, 2009 | 10:30 PM
08 c350
thanks kaku, saw those alreaady.
i was actually lookin for a DIY with pics cuz yeah ima noob -___-
but yyeaaa good looks on thattt
Old Apr 23, 2009 | 03:15 AM
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
Not to sound like a dick, but... the best way to learn how to DIY is to Do It Yourself. Try without the additional help... you don't really need any more than what's on the forum.
And before anyone chimes in with a counter-flame, consider that I did my own Backup Camera install without instructions. I'm not much of a DIYer to start off with either.
Old Apr 23, 2009 | 06:53 AM
Ron Jr's Avatar
As Rick said try doing it first. It isn't very hard just open the hood and take a look.
Old Apr 23, 2009 | 09:54 AM
AMGTTV8's Avatar
2026 AMG GT63 Pro
HAHAHAHA I like that one...
Old Apr 23, 2009 | 01:56 PM
08 c350
Yeahh true nothing wrong with being a little cautious id rather go do something with guidelines and have a better chance of not messing something up and having to pay mercedes a crap load of money to fix. But yeah i understand what you mean by actually doing it urself but yah id prefer to be more cautious. Thanks though ;D
Old Apr 24, 2009 | 04:49 PM
Bokx_350's Avatar
C350
I really hope you guys are not suggesting he experiments on his $40k car!!
I too have done lots of things myself, including a MM retrofit from an Euro COMAND unit, GPS antenna, ECU removal and the backup camera. And let me tell you, these are close to impossible without guidance.
I tried changing my fog light and got stuck cause I couldn't reach the screws at the back of the light after removing the grill; after about 30 mins of getting no where, I decided to stop. Ron posted a brief description of what was needed to do on another thread (thanks again Ron), but I'm still confused. I could go with Rick Hunter's advise and just keep pushing it, but chances are that I miss a screw or a plastic snap and brake something.
I agree with the OP that there is no clear guide to fully swap a fog light, so I will join him and ask if someone is willing to help us out. And if you think we are asking for too much, then don't even bother answerting cause clearly the question wasn't directed to you.
Old Apr 25, 2009 | 12:14 AM
Jae Duk's Avatar
'09 C63
+1
Don't worry you'll find it...if you need help look in the owners manual and you'll figure it out. I'm not much of a DIY like rick as well so it ended up taking me 30 min just to figure out the eyelids
Old Apr 25, 2009 | 12:32 AM
aranu's Avatar
C230 2009 , E320 1996, C230 Coupe 2002
Heres a DIY on Eyelids. I looked around for this on search and saved it for when i need it. I do random searching often for this stuff.... good luck, and if u do this you should post your own DIY making it more thorough...
https://mbworld.org/forums/c-class-w...ed-eyelid.html
Old Apr 25, 2009 | 08:09 PM
08 c350
yeah im still tryna figure out my eyelids lol i made progress today though i was lookin underthe hood and i got the cover unscrewed, just is there a way to take off that top part covering the lightbulbs from underthe hood?
Old May 10, 2009 | 12:11 AM
Andr3an's Avatar
w204-C300
+1, can anyone who changed the foglights with HID post a DIY or instructions, please.
Old Nov 5, 2010 | 11:41 PM
momoged's Avatar
W204 C300 4matic Sport 2010
hey guys.. after installing hids in the fogs, do u leave them on at all times to prevent short life on the kit? coz my c300 has the corner illumination feature, and i think the hids would die faster than usual if they turn on and off that often.
I'm still deciding whether to get them or not..
Old Nov 6, 2010 | 12:48 AM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
Thanks ;D
I just changed mine today
It's pretty simple and straight forward... Start with the passenger side eyelids/ lowbeam since you'll have more space to fit your hand... Twist the eyelids/ lowbeam cap counterclockwise to gain access in the main assembly... For the eyelids, twist and pry out the bulb assembly, it's ok to use a little bit of force, a long nose pliers will make the job easier... Once you have access on the bulb you can now switch it out with LEDs, make sure you test it first before putting it back since LEDs have to be put in a certain way, If it didn't light up just put it the other way... For the lowbeam, twist the cap to gain access in the main assembly, rotate it counterclockwise to remove the bulb assembly and switch out the bulbs
The same steps applies for the driver side but you have a tighter space to manipulate your hand around... manipulating your hand in tight spaces is an art where we can all improve if practiced regularly
For the fogs... you will see 3 torx screws on the mesh grill surrounding the fog light assembly... remove all three and pull out the mesh grill... you'll have a lot of room to work around it, twist the bulb assembly and pull it out, switch out the bulbs and put everything back in place
I know pictures or diagrams is a big help but as long as you take your time and analyze each step you'll do just fine
