Any thoughts on the 3.0L V6 in our C300s?
Personally I find it to be quite a good engine and it has a good amount of power when compared to the 2.5L V6 I drove before. The transmission seems to make good use of the horsepower, although in manual mode it can be annoying since it doesn't behave very well sometimes (at least compared to a true manual).
Any thoughts or opinions anyone?
as far as the 3.0l v6..it's an adequate engine once you accelerate past the 25 mph mark..the only minor complain I have is the slow start off the block..dunno if it's due to the weight of the car, ecu program or not enough torque from the engine..
I find the 7-speed auto to really smooth and precise in sport mode. In terms of shifting with "manual" it's a little too slow to respond but that's what you get with an entry level luxury sedan. If you really want to take advantage of the manual mode, keep the rpms between 2500 and 5000. I find in this range the car responds better to gear changes. Once you go over 5000, and shift, it seems like there is a lag, or if you down shift and the gear you select puts you under 2500, it feels like it's thinking about if it really wants to hit that gear. From about 2500 - 4500 the car pulls really well. Just my observations, not the truth
My biggest complaint with the powertrain is the auto transmission in my C350. While it is brilliant in predicting gears and being quick to change gears when you want it to, it can be a little smoother. When it down shifts while coasting, you definately feel a jerk from it, a feeling that is absent in the lexus cars in my family
The 7G is a good transmission, when left to do its job. But the inability to specifically choose a gear via manual mode frustrates me.
