Subtle brake upgrade
Old 08-07-2009, 06:29 AM
vic viper's Avatar
S213
My car came equipped with the smallest brakes the Sports Package has to offer, 295mm cross drilled rotors.
Looks so small and puny and doesnt match the overall stance of the car
IMO.
So I swapped them for 350 brakes :
Now were talking
C300 cars have the same stock setup as my car, here is what you need if you want to upgrade:
2x Rotors A204 421 10 12 (cross drilled, also available without holes)
2x Caliper carrier A204 421 11 94
2x Spring A000 993 46 07
1x Left caliper A204 421 35 81
1x Right caliper A204 421 36 81
1x Pads A005 420 10 20
Old 08-07-2009, 07:57 AM
Petje's Avatar
W205 C400
Nice upgrade
Think a Brembo big Brake kit cost the same?? Not for you, but normaly these oem calipers are expensive or not?
Old 08-07-2009, 08:50 AM
Mr Enigma's Avatar
MB W204, VW Polo, Audi R8 V10 - SOLD.
What's the price for the upgrade?
Old 08-07-2009, 09:30 AM
vic viper's Avatar
S213
Counting with todays rates I would say around 1250 Euros
Old 08-07-2009, 09:36 AM
PolePosition's Avatar
C350
Looks good! How about the rears? I have a C350 with that setup in the front but my rears are different, would it be possible to retrofit a OEM setup with drilled rotors in the rear?
Rich
Old 08-07-2009, 09:46 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Rich
You should be able to get aftermarket cross drilled rotors
Old 08-07-2009, 09:50 AM
tanktube67's Avatar
Now were talking
Good job,
Originally Posted by Petje
Nice upgrade
I'm looking to get BBK but, I'm still trying to convince my wife to let me spend 5K
Old 08-07-2009, 12:29 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Rich
+1
I'd be nice to get a BBK up front and somehow use the front setup in the rear.
Old 08-07-2009, 02:54 PM
Sportstick's Avatar
Another round of ICE
Very interesting and looks nicely done.....What about the issues of front/rear proportioning? This would seem to invite the tail end get very light under braking?
Old 08-07-2009, 03:14 PM
Diesel Benz's Avatar
I don't know which discs the 204.089 has but in my opinion the brakes are far too sensitive, it makes driving uncomfortable. Perhaps I should buy your old discs, I assume it would allow 16 inch winter tyres too which is not possible with the current discs on our 204.089. Bigger discs look a lot better but I'm too old to care about the looks.
Old 08-07-2009, 06:14 PM
vic viper's Avatar
S213
204.089 use the same size rotors as my above upgrade, 320mm
16" wheels do work on this setup, at least the OE wheel "Pristix" wich I have tested.
Old 08-07-2009, 07:24 PM
joshg1001's Avatar
2017 E300
I think MB does the best looking brakes as standard OEM than any other brand (within reason). Great choice on the upgrade.
Old 08-07-2009, 08:12 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
You mean MB outsourced the best looking brakes as standard OEM :p Our brakes were outsourced to Continental. C63s were outsourced to Brembo.
Old 08-08-2009, 12:34 AM
Derspeed's Avatar
X3 and 2012 C coming soon
You answered my long-time question. You can't just swap carriers and rotors. Rats!
Old 08-08-2009, 02:42 AM
vic viper's Avatar
S213
There is a small downside, the new brakes are at least 30% heavier than the previous setup
The 295mm caliper is made entirely out of aluminum and is very light, the 320mm caliper is mostly steel and only part aluminum.
Old 08-08-2009, 11:51 AM
Sincity's Avatar
Vic: Are they 2 or 4 pistons?
Old 08-08-2009, 12:56 PM
vic viper's Avatar
S213
Theyre one piston floating calipers.
Old 08-08-2009, 12:58 PM
vic viper's Avatar
S213
They are one piston floating calipers.
This gets more and more common on newer cars now, theyre alot lighter and not as complex as multiple piston calipers, its also easier to replace pads on a floating caliper.
Multiple piston calipers are though still often found on more extreme cars.
Old 08-08-2009, 01:11 PM
Krytech's Avatar
Good to know, I've often wondered how much heavier my rotors where than the C300.
Do you notice any difference driving over choppy roads?
Old 08-08-2009, 01:17 PM
vic viper's Avatar
S213
No, I actually havnt fel any difference in acceleration or uneven surfaces.
Old 08-08-2009, 08:03 PM
albert101's Avatar
W204 C280
Did you replace the rears or just the fronts? Or are the rears the same on your car and the C350? Great upgrade! I was thinking about doing the same on mine. Do you feel an improvement in braking power?
Old 08-09-2009, 02:50 AM
vic viper's Avatar
S213
Yes, the brakes feel a lot firmer now, it feels that I have a alot of stopping power if I would need it,
The rears are still stock but the only real difference there is that the 350 rear brakes are ventilated, there is not much diameter difference.
Old 08-09-2009, 10:58 AM
Nuru's Avatar
S350 BT 4MATIC
Vic, another good job on the upgrade and the procedure:
I found these prices sofar:
2x Rotors A204 421 10 12 (cross drilled, also available without holes) - $50.40 ea.
2x Caliper carrier A204 421 11 94 - $124 ea
2x Spring A000 993 46 07 - $8.00 ea
1x Left caliper A204 421 35 81 - $334
1x Right caliper A204 421 36 81 - $326
1x Pads A005 420 10 20 - $73.60
Old 08-09-2009, 01:42 PM
Sincity's Avatar
I see. I thought they would be 2-piston or 4-piston front calipers like the w204 Sport packaged cars.
Old 08-09-2009, 01:58 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Do you know of a source for rear cross drilled rotors?
Quick Reply: Subtle brake upgrade
