Powered subwoofer installation help
Old Aug 17, 2009 | 09:43 AM
sycuan73's Avatar
Mercedes C300
I'm a first time DIYer and have been reading the boards for help on my Kenwood KSC-SW10. I'm planning on placing the subwoofer under the passenger side seat. I've removed the head unit and tapped into the rear speakers using the harness provided in the subwoofer. Okay here's my question. How to I route the wires from the headunit to the subwoofer. Is there a hole or path I can take to get to the right side or do I have to remove the glove compartment. I started removing some of the glove compartment before I decided to write this post and ask for a little help before I take everything apart. Thanks in advance guys
Old Aug 17, 2009 | 01:36 PM
Norm01's Avatar
2011 E550 Coupe
Do you have the HK surround sound or standard. I ask because if you have the HK you should tap into the sub for signal as the rear speakers may not present enough bass signal. As for the wires, run them down the kick panel and under the carpet.
Old Aug 17, 2009 | 03:20 PM
sycuan73's Avatar
Mercedes C300
I have the standard Audio 20. I don't know why I'm having a problem finding a hole to run the wires behind the head unit to get to the right kick panel. Do you think I should go down the left one instead.
Old Aug 18, 2009 | 11:13 AM
Chi-Benz's Avatar
08 C300 4-Matic, P1 P2 MM iPod Kit
I would run the wiring through the glove box on down under the carpet. I'll be putting in this 8" Blaupunkt powered subwoofer:
//http://www.amazon.com/Blaupunkt-Compact-powered-subwoofer-70-watt/dp/B000S6GVPO
of course I'm biased (German sub for German car) but it has received excellent reviews. I'll tap into the subwoofer signal as norm stated.
Sycuan73 - Did the subwoofer fit under the passanger seat?
Old Aug 18, 2009 | 11:56 AM
M-bENZ's Avatar
Corrolla
Chi Benz,
Do you have any pics of your setup ? The site that you posted above is that an amp and sub comes in 1 piece??
Thanks,
Andy
Old Aug 18, 2009 | 11:59 AM
vic viper's Avatar
S213
I am interested in how you are going to fit a woofer under the front seat?!
Old Aug 19, 2009 | 09:57 AM
Chi-Benz's Avatar
Originally Posted by M-bENZ
Chi Benz,
Thanks,
Andy
Hi Andy,
I haven't received the unit yet. Still trying to figure out where I want to mount it. Yes its an amp and sub all in one.
Old Aug 19, 2009 | 10:32 AM
SuperDavid's Avatar
C350 2008
Hi,
I have a five channel amp (powerbase) was installed in the floor of passager seat. Subwoofer 12" Rockford P3 in the truck, and one Pre-amp in glovebox. I will send the picture today. The front door speakers were replace with HK, the rear door speakers are original, are very difficult to replace or impossible. Sound is very good.
Old Aug 20, 2009 | 12:23 AM
sycuan73's Avatar
Mercedes C300
Chi,
The kenwood subwoofer fits perfectly under the passenger seat. It doesn't rattle my windows or anything, but it gives my stock system that extra bass I'm looking for. I also changed out the front speakers with some infinity kappa 60.7 cs. I have to admit the system sounds great now with not too much work.
Old Aug 20, 2009 | 03:07 PM
Chi-Benz's Avatar
Originally Posted by sycuan73
Chi,
Anyway you can take some photos of this sub installed? How did you run the wiring specifically? Were the Kappa's a direct fit or? Thanks.
Old Aug 20, 2009 | 05:35 PM
M-bENZ's Avatar
Corrolla
Ya need to post all the pics of your set up here lol. YES I mean it
Andy
Old Aug 20, 2009 | 07:28 PM
Norm01's Avatar
2011 E550 Coupe
Here's mine, sorry about the bad pictures. JL Audio mono 500w mounted in what I think is the diesel European battery location. No holes drilled, made a templated that slid into the compartment. The sub is a W6 sealed as it fits perfectly, made a strap and used the OEM strapping loops. You could remove this system and there would not be a mark of the installation. Added this to a MM HK system. The car is so tight that the car actually pressurizes, the tump is wild however the pressure can hurt your hears.
Attached Thumbnails Powered subwoofer installation help-img_0187.jpg   Powered subwoofer installation help-img_0189.jpg
Old Aug 20, 2009 | 08:37 PM
M-bENZ's Avatar
Corrolla
I like ur set up and now questions, did you powered ur amp from ur battery ? How did u get the signal to the amp ? did u tapped from the stock sub ? and how about the remote wire ? where did u hooked it up to ? Sorry for 2many questions at one lol.
Thanks,
Andy
Old Aug 22, 2009 | 06:20 AM
Norm01's Avatar
2011 E550 Coupe
Thanks,
Andy
Ran power wire from the front Battery. Signal is a "high level" input to the amp taken from the rear sub, you actually tap into it at the stock rear amp. Turn on is an accessory signal taken at the rear power module. I set the amp level and just leave it, you could run a remote to the front if you want.
Old Aug 22, 2009 | 01:48 PM
M-bENZ's Avatar
Corrolla
I get the first part but im still confused on the remote wire..what do you mean by that (highlighted) ? Can u be more specific ?
Andy
Old Aug 22, 2009 | 02:29 PM
Norm01's Avatar
2011 E550 Coupe
Andy
There are two types of remote. One is the remote turn on, just take an accessory signal from the rear power module to turn on the amp. The other is a remote bass adjust that is essentially a potentiometer you can mount up front to control the bass.
Old Aug 22, 2009 | 02:33 PM
M-bENZ's Avatar
Corrolla
thats what I meant.
Andy
Old Aug 25, 2009 | 09:48 AM
Chi-Benz's Avatar
Nice setup Norm. Thanks for the pictures!
Old Aug 28, 2009 | 10:21 AM
Chi-Benz's Avatar
Hey sycuan73,
Where are some pics of your setup??? I want to see this thing under your seat...
Old Nov 7, 2009 | 08:20 AM
Norm01's Avatar
2011 E550 Coupe
TTT fo Mark, hope this helps.
