Tires Michelin
What kind of noise?
I've been hearing some kind of new sound in my car and can't place it.
Also, how often have you had to rebalance the tires?
Here's a link:
http://www.ehow.com/how_5019913_diag...r-cupping.html
I would think that a tumping sound, if coming from the tires, would indicate something serious such as a bulge in part of the thread.
Here's a link:
Please correct me if I'm wrong, but I though you weren't suppose to rotate these tires as the rear tires are wider than the fronts.
I just checked Continental's website, and they recommend rotating every 6,000-8,000 miles.
Michelin's website also recommends rotating every 6,000 - 8,000 miles.
owned it since 11,000 miles now at 41,000 same issues, dealer has road force balanced and aligned already with no change!
Back at the shop,we will see what they say,but will be switching to a softer tire, to absorb the stiff suspension a bit better,and to keep tire surface on pavement longer,this will keep the michelin stiff sidewall and stiff factory suspension combination out of play,which is one of the contributors of tire cupping !
Leaning toward toyo proxes 4 plus !
