55W DDM HID issues please help.
Old Feb 14, 2010 | 09:14 PM
boostin500's Avatar
C300
I got the 55w kit- (no error code fixer thingy) after the install everything worked grand no issues, now a week later I’m having issues with them flickering (very slight very, hard to notice but you can tell). My question is I thought there we no need for the error correctors as its the 55w kit. And why would the issue just start, if there was a issue would it not have started at first install. I am so confused there is certainly a voltage issue but its just weird. Can anyone shed some light on this (pun intended). do the error correctors fix an issue of this nature assuming its voltage? The driver’s side light has the most issues. (2010 c300)
Old Feb 14, 2010 | 09:23 PM
sebydeleon's Avatar
merecedes c200k 2009
If there is no error in the connections, the ballast or the bulb came wiyh defects.
Old Feb 14, 2010 | 10:09 PM
Richard2011's Avatar
2015 BMW M235i 6MT
Even if you have the 55w DDM kit, you still need error cancellors.
Old Feb 15, 2010 | 09:56 PM
boostin500's Avatar
C300
Spoke with DDM rep, they told me to give the error correctors a go. Will keep you posted.
Old Feb 15, 2010 | 10:30 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
warranty! call DDM
Old Feb 17, 2010 | 11:40 AM
E92-Lighting's Avatar
Former Vendor of MBWorld
BBS LM's 18's + Kics
i would recommend 35W hid kits, over 55W
Old Feb 17, 2010 | 01:44 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
I know OEM are 33w, but why would you recommend 55 over 35? Safety precaution
Old Feb 17, 2010 | 04:17 PM
dadangman's Avatar
'09 C350
yes u do, get those decoders. 20 bucks a pair? http://store.ijdmtoy.com/Canbus-Deco...adapter_03.htm
if it's a conversion kit from Halogen to HID then u gotta have the decoders, if ur car always have HID and u just changing the bulbs then u don't need the decoders..
Old Feb 17, 2010 | 04:26 PM
alan111's Avatar
2002 Porsche 911 Carrera 4 Cab
Why is that?
Old Feb 17, 2010 | 09:00 PM
boostin500's Avatar
C300
Even though I don’t have the decoders to try yet from what I’m learning, even though its the same voltage (55w) as the stock halogen the computer is sending some sort of "pulse" to be sure that there is a complete circuit. I can only assume since the HID bulb does not a have a filament it responds with a flicker on sorts. This is just my very uneducated opinion.
Old Feb 18, 2010 | 01:28 AM
dadangman's Avatar
'09 C350
u are right on the voltage part.... if there's no error message then maybe that's not the problem.. maybe it's ur bulbs... or some connection is loose. try to switch bulbs and see which one is giving u the problem..
Old Mar 3, 2010 | 09:09 PM
boostin500's Avatar
C300
*****UPDATE*****
The Error cancellers finally made it and they work like a charm, no more flickering!
Old Mar 3, 2010 | 09:15 PM
ldtCapitan's Avatar
C300 Luxury
Awesome. On the DDM Support site they say that all Mercedes past 2002 regardless of make need error cancelers, I trust DDM, but good to see I didn't install them for no reason
